[GRASS-user] setting snap an min_area for v.in.ogr
Moritz Lennert mlennert at club.worldonline.be
Thu Jun 9 02:26:58 PDT 2016
On 09/06/16 10:47, Uwe Fischer wrote:
> Hello List,
> why are there no input boxes for snap threshold and min_area in the
> v.in.ogr menu in GRASS 7.0.3? I think those values are important to
> control the process. On the command line, the values can be entered.
This is an old discussion. See [1] for example.
The menu entry File->Import vector data->Common import formats actually
does not launch v.in.ogr as such, but a GUI import wizard which launches
v.in.ogr.
The general gist of those in favor of simple versions of the wizard is
that the wizard should only show the basic functionality to ease use.
Those who want to use the full-power v.in.ogr can launch it using
v.in.ogr --ui in the console.
In GRASS7.2 the main import wizard actually uses v.import which allows
reprojection during the import. It also gives access to the more
detailed parameters. However, v.import does not provde min_area. If this
is considered necessary, then a ticket should be opened.
Moritz
[1] https://trac.osgeo.org/grass/ticket/2042
