[GRASS-user] use of g.list inside r.mapcalc expression
Sajid Pareeth spareeth at gmail.com
Wed Jun 15 06:36:20 PDT 2016
Hi Vero
If I got you right, may be this could be a better approach,
#Assuming you are using MOD13Q1 product, and for example maps from
MOD13Q1.A2015353.h18v05.006.2016007180711.hdf;
map=`g.list rast pat=MOD13*_EVI`
for tile in ${map}; do
    ## Put the common part (In this case - MOD13Q1.A2015353.h18v05) of the
map name into a variable.
    i=`echo $map|cut -c1-23`
    r.mapcalc --o expression="${map} = if(${i}_pixel_reliability` == 0,
${map}, null())"
done
Sajid
On Wed, Jun 15, 2016 at 2:58 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hello everybody,
> Is it possible to use r.mapcalc with `g.list` as part of the
> expression??? Something like:
> tiles=(h11v11 h12v11 h12v12)
> for tile in ${tiles[*]}
> do
> r.mapcalc --o expression="`g.list rast pat=MOD13*$tile_EVI` =
> if(`g.list rast pat=MOD13*$tile_pixel_reliability` == 0, `g.list rast
> pat=MOD13*$tile_EVI`, null())"
> done
> it worked only once in a test case with one image per tile... when I
> tried to run it again for the whole set, i get parse error:
> syntax error, unexpected ';', expecting '('
> syntax error, unexpected ';', expecting ')'
> Parse error
> ERROR: parse error
> Which would be best practice in this case? Is this use even possible?
> I know I can register maps in temporal framework and use
> t.rast.mapcalc, but I want to keep year and doy in mapnames and
> neither t.rast.mapcalc nor t.rast.algebra have granularity suffix
> option yet (only numerical suffix).
> Ah, I use grass trunk (7.3) freshly updated to r68692.
> thanks much in advance!
> Vero
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160615/ca9ab1c1/attachment.html>
