[GRASS-user] Best workflow
Markus Neteler neteler at osgeo.org
Tue Jun 28 14:04:22 PDT 2016
Hi Paul,
On Tue, Jun 28, 2016 at 8:32 AM, Paul Meems <bontepaarden at gmail.com> wrote:
> Thanks Markus for your suggestion.
> I first tried Stefan's suggestion of using a VRT-file.
> I have 1300 tiff-files with a combined file size of 400GB. Creating the VRT-file was no problem, but when I tried to import the VRT-file in GRASS7 using r.in.gdal GRASS crashes and dies.
Huh - should not happen .. But which operating system are you using,
which GRASS version etc?
You may post the result of
g.version -bge
> Loading the same VRT-file in QGis did take some time to load but it worked.
Please post also the output of
gdalinfo yourfile.vrt
> So I think I need to set-up a GeoServer after all, just to get a small portion of my height data to process in GRASS without worrying about polygons that are partially on multiple tiff-files.
> Of course I'm open to any other suggestion. As said I'm new to GRASS.
Let's try harder, data in the your file size range should not be a problem.
Markus
