[GRASS-user] 3d boreholes with v.extrude on different plane
Anna Petrášová kratochanna at gmail.com
Tue Mar 1 17:35:07 PST 2016
It seems that everything works as expected, just the bottom z value of the
vectors is very close to each other so you can't see much difference.
Anna
On Tue, Mar 1, 2016 at 7:35 PM, Alec Ventura <alecventura at hotmail.com>
wrote:
> Anyone help please? I am desperate [image: Emoji]
> From: alecventura at hotmail.com
> To: grass-user at lists.osgeo.org
> Date: Mon, 29 Feb 2016 22:42:23 -0300
> Subject: Re: [GRASS-user] 3d boreholes with v.extrude on different plane
> Sorry my delay, here are 6 of my boreholes. Even that they have
> different zshift values, they are been draw on the same plane
> Tnks,
> Alec
> From: kratochanna at gmail.com
> Date: Sun, 28 Feb 2016 21:21:04 -0500
> To: alecventura at hotmail.com
> CC: grass-user at lists.osgeo.org
> Could you send me the data using v.pack?
> On Sun, Feb 28, 2016 at 7:16 PM, Alec Ventura <alecventura at hotmail.com>
> wrote:
>  | Mapset:          Map
>  | Location:        Tests
>  | Database:        C:\Users\Vulcan\Documents\grassdata
>  | Title:
>  | Map scale:       1:1
>  | Name of creator: Vulcan
>  | Organization:
>  | Source date:     Sun Feb 28 19:14:22 2016
>  | Timestamp (first layer): none
>  | Map format:      native
>  |   Type of map: vector (level: 2)
>  |   Number of points:       0               Number of centroids:  0
>  |   Number of lines:        0               Number of boundaries: 0
>  |   Number of areas:        0               Number of islands:    0
>  |   Number of faces:        25              Number of kernels:    1
>  |   Number of volumes:      0               Number of holes:      0
>  |   Map is 3D:              Yes
>  |   Number of dblinks:      1
>  |   Projection: UTM (zone invalid)
>  |               N:  7074915.22090919    S:  7072919.88337081
>  |               E:     383218.654546    W:   381227.96859996
>  |               B:               100    T:              2000
>  |   Digitization threshold: 0
>  |   Comment:
>  |     Generated by v.extrude from vector map <tmp at Map>
> and
>  | Mapset:          Map
>  | Location:        Tests
>  | Title:
>  | Map scale:       1:1
>  | Organization:
>  | Source date:     Sun Feb 28 19:15:15 2016
>  | Map format:      native
>  |   Map is 3D:              Yes
>  |               N:  7064064.24981919    S:  7062068.91228081
>  |               E:     371187.626007    W:   369196.94006096
>  |               B:              1000    T:              2000
>  |   Comment:
> This are 2 tests that I made and I notice that B and T values are the
> values that I put on zshift and height... But this don't indicates nothing
> about the plane... how can I reference the sea level plane? I am a little
> lost here haha.
> Tnks,
> Alec
> Date: Sun, 28 Feb 2016 19:09:03 -0500
> What does v.info say?
> On Sun, Feb 28, 2016 at 7:05 PM, Alec Ventura <alecventura at hotmail.com>
> wrote:
> 'as 3d' is selected. I have 83 boreholes and all of then have their base
> on the same plane, and it shouldn't be.
> Tnks,
> Alec
> Date: Sun, 28 Feb 2016 18:02:58 -0500
> Hi,
> there is a switch in the 3D view vector gui to switch between displaying
> as 3D and on a surface. You might check if that could be the problem.
> Anna
> On Sun, Feb 28, 2016 at 5:43 PM, Alec Ventura <alecventura at hotmail.com>
> wrote:
> Hello folks, I am trying, again, to draw some 3d boreholes, I was able to
> draw then but when I was analizing my results I notice that all my
> boreholes was all with the same z value, which is strange since I have
> different zshit and height values for each of my boreholes. So I guess i
> missundestood the zshit value. I need 3d boreholes that are draw from
> different levels (different Z coordinates) and of course with different
> sizes (heigths). Is there a way to do this? what I am missing here? I was
> back to Gene implementation:
> http://osgeo-org.1560.x6.nabble.com/3D-geological-volume-modeling-raster-3D-is-it-really-possible-td4980148.html
> http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
> But then I realize that they boreholes are at same plane too, just don't
> appear to because of perspective.
> I appreciate any help.
> []s
> Alec Ventura.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> _______________________________________________ grass-user mailing list
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160301/05cf3df7/attachment-0001.html>
