[GRASS-user] Parallel proccess with pygrass and mapcalc
Lorenzo Bottaccioli lorenzo.bottaccioli at gmail.com
Wed Mar 2 09:10:12 PST 2016
Hi I'm writing a code in python able to perform several mapcalc operation
on various rasters. I'm using GRASS 7.0.1 and Python 2.7. I'have my files
stored in /home/myuser/rasters/ and they are linked to GRASS with
r.external. The out put of the operation are going out of GRASS in
/home/myuser/tmp/ with r.external.out.
I have written this code from the example provided in (
https://grass.osgeo.org/grass70/manuals/libpython/pygrass.modules.interface.html?highlight=parallelmodulequeue#pygrass.modules.interface.module.ParallelModuleQueue)
 but there is no difference in terms of time between setting nproces=1 or
nproces=8. How is possible? How can I achieve improvements?
The task that the code need to do is to read data from a file containing
datetime and 2 coefficients k1 and k2. Than need to multiply and sum the
input raster as out = input1 * k1 + input2 * k2.
The code that i have written is:
import pandas as pd
import os
import grass.script.setup as gsetup
import grass.script as g
import time
import copy
from grass.pygrass.modules import Module, ParallelModuleQueue
def main():
   #set GRASS LOCATION AND MAPSET
    gisbase = os.environ['GISBASE']   # Grass 7.0svn
    gisdbase = os.path.abspath("/home/myuser/grassData")
    location = 'mylocation'             # Grass Location.
    mapset = 'mymapset'
    gsetup.init(gisbase, gisdbase, location, mapset)
   #READ INPUT DATA FOR RASTER CALC
    df = pd.read_csv('input.csv', sep=";", index_col='Date Time',
decimal=',')
    df.index = pd.to_datetime(df.index, unit='s')
month={1:'17',2:'47',3:'75',4:'105',5:'135',6:'162',7:'198',8:'228',9:'258',10:'288',11:'318',12:'344'}
hour={4:'04',5:'05',6:'06',7:'07',8:'08',9:'09',10:'10',11:'11',12:'12',13:'13',14:'14',15:'15',16:'16',17:'17',18:'18',19:'19',20:'20',21:'21',22:'22'}
    minute={0:'00',15:'15',30:'30',45:'45'}
    directory='/home/myuser/raster/'
    tmp='/home/myuser/tmp/'
    g.run_command('r.external.out', directory=tmp, format="GTiff")
 #MAPCALC
    start_time = time.time()
    mapcalc_list = []
    mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
    queue = ParallelModuleQueue(nprocs=8)
    for dfix in df.index:
        if 5<=dfix.hour<20:
            input1 = 'input1_' + month[dfix.month] + '_' + hour[dfix.hour]
+ minute[dfix.minute]
            input2 = 'input2_' + month[dfix.month] + '_' + hour[dfix.hour]
            out = ' " ' + str(dfix.date()) + '_' + str(dfix.time()) + ' " '
            new_mapcalc = copy.deepcopy(mapcalc)
            mapcalc_list.append(new_mapcalc)
            m = new_mapcalc(expression="%s =
%s*%i+%s*%i"%(out,input1,df.ix[dfix,'k1'],input2,df.ix[dfix,'k2']))
            queue.put(m)
    queue.wait()
    print("--- %s seconds ---" % (time.time() - start_time))
Best,
Lorenzo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160302/3143d532/attachment.html>
