[GRASS-user] snapping points to lines issue
Bartolomei.Chris Bartolomei.Chris at ensco.com
Mon Mar 14 11:13:39 PDT 2016
Has anyone had issues using the v.clean, v.distance, v.patch, v.clean trick to snap points to a nearby set of lines?
I am running GRASS version 6.4.4 on a Windows 7 PC.
I have USGS stream gauge locations I am trying to snap to a stream and then create a network ...
there are 15 gauges located from 1.9 to 260 meters from my stream vector and using the above process only 11 of the 15 "snap" to the stream...
I have attached the mapset containing all of the data and maps, a text copy of the commands I use in my shell script, and a readme with set-up instructions if you want to use my mapset...
I also included a few images of what is happening for a quick visual.
The grey circles are the gauge locations and the red triangles are the "snapped" points on the stream vector.
The problem does not seem to be related to distance (failed points are from 2 to 260m away, successful ones are in a similar range)
Any help would be greatly appreciated!
Thank you
Chris
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
bartolomei.chris at ensco.com
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
Type: application/x-zip-compressed
Desc: Snap_point_error_images.zip
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160314/395dcc83/attachment-0001.bin>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160314/395dcc83/attachment-0002.txt>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160314/395dcc83/attachment-0003.txt>
