[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Michael Barton Michael.Barton at asu.edu
Tue Mar 15 02:20:57 PDT 2016
After this problem was discovered 4-6 months ago, we've been working on a way to remedy it. We have a basic plan that William has suggested, but it takes some time to work out how to implement it. So far, no one has had the time needed to do this. It seems solvable with some effort.
My understanding is that SIP is a new security feature. Disabling it leaves the Mac at the same level of security it has under Yosemite.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Mar 15, 2016, at 11:00 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Adam Dershowitz <adershowitz at exponent.com> writes:
>> So it looks like this is actually the known problem with System
>> Integrity Protection. I hate to turn off a security feature, and do
>> two reboots, to be able to run a single application. Has there been
>> any progress in getting this fixed?
> No - I have the feeling that the ones using GRASS on OS X are still
> avoiding upgrading to El Capitan, and the ones who have are out in the
> cold. I raised the issue several times already.
> I slowly really think the best would be to abandon GRASS on OS X and
> focus on setting up an official docker image which can be used on OS X,
> Windows and Linux.
> Please convince me otherwise.
> Cheers,
> Rainer
>> Thanks,
>> -- Adam
>> From: Adam Dershowitz <adershowitz at exponent.com>
>> Date: Monday, March 14, 2016 at 11:21 PM
>> To: Michael Barton <Michael.Barton at asu.edu>, grass-user grass-user
>> <grass-user at lists.osgeo.org>
>> Subject: Re: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>> wxPython (missing)
>> And, I just tried to run 6.4, which I still had installed, and it also
>> won’t run, but with a different error:
>> Python 2.7.10 found.
>> Cleaning up temporary files ...
>> Starting GRASS ...
>> Traceback (most recent call last):
>> File
>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
>> line 37, in <module>
>> from core import globalvar
>> File
>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/core/globalvar.py",
>> line 74, in <module>
>> import wx
>> File
>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/__init__.py",
>> line 45, in <module>
>> from wx._core import *
>> File
>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py",
>> line 4, in <module>
>> import _core_
>> ImportError: dlopen
>> (/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so,
>> 2): Library not loaded:
>> /Users/Shared/unix/wxpython-cocoa-lion/lib/libwx_osx_cocoau-3.0.dylib
>> Referenced from:
>> Reason: image not found
>> Error in GUI startup. If necessary, please
>> report this error to the GRASS developers.
>> Switching to text mode now.
>> Hit RETURN to continue...
>> Has anyone had any luck running GRASS on 10.11 at all?
>> -- Adam
>> From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of
>> Date: Monday, February 15, 2016 at 3:24 PM
>> To: grass-user grass-user <grass-user at lists.osgeo.org>
>> Subject: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>> wxPython (missing)
>> The packaging seems to have gone awry. I've been out of the country
>> and then sick since returning. Once I get well enough to get to the
>> office, I'll try and fix this.
>> Michael
>> C. Michael Barton
>>    On Feb 15, 2016, at 12:59 PM, grass-user-request at lists.osgeo.org
>>    wrote:
>>    From: gene <martin.laloux at gmail.com>
>>    wxPython (missing)
>>    Date: February 15, 2016 at 11:55:37 AM MST
>>    To: <grass-user at lists.osgeo.org>
>>    With the 7.0.3 version of GRASS GIS on the Mac (M.Barton)
>>    <http://grassmac.wikidot.com/> I can only launch GRASS-7.0.app
>>    (7.0.3) in
>>    text mode.
>>    When I try to launch the App or use g.gui wxpython in the Grass
>>    shell the
>>    error is:
>>    "Launching <wxpython> GUI in the background, please wait…
>>    ERROR: wxGUI requires wxPython. No module named wxversion
>>    In the 7.0.2 version, wxPython is installed in
>>    /Applications/GRASS-7.0.app/Contents/MacOS/etc/python (wx,
>>    wxpython and
>>    pyparsing.py and wxversion.py) and it works.
>>    But none of these files/folders exist in the same folder of the
>>    7.0.3
>>    version
>>    Compilation error ?
>>    The size of the zip files are also different (80.19 and 83.89 for
>>    GRASS 7.01
>>    and GRASS 7.02, 35 .12 for GRASS 7.03)
>>    Many thanks
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Rainer M. Krug
> email: Rainer<at>krugs<dot>de
> PGP: 0x0F52F982
