[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Rainer M Krug Rainer at krugs.de
Tue Mar 15 06:14:46 PDT 2016
Adam Dershowitz <adershowitz at exponent.com> writes:
> Yes, SIP is a new security feature that prevents any applications from
> writing to a few key OS paths.  I believe that it really is that simple.
> (see:  https://support.apple.com/en-us/HT204899 )
> Which, does beg the questionŠwhy does running GRASS require writes to any
> of these folders?  That suggests that GRASS is doing something that it
> shouldn¹t be doing.  Why should it be writing to system folders at all at
> runtime?
> It is the only application that I have run into that has any problems with
> SIP.  It would seem that this should be an easy fix.  (for example just
> use /usr/local instead of /usr, or whatever the problem folder is).
If I remember correctly, one reason is the use of DYN_LIB path in
GRASS.
The reason is not the writing into these protected directories. I
managed to compile and run grass 7.1 dev (including GUI) using homebrew, but it required
many steps of ignoring errors, make, make install, make, make install as
the directories where the compiled libraries are found were somehow not
available during the compilation process. And the source directory as
well as the compiled and installed files are needed for running GRASS.
So I would say it is more a structural problem (how GRASS is compiled, installed,
how paths to libraries are passed, ...) and not a problem of GRASS not
running on El Capitan.
Cheers,
Rainer
> -- Adam
> On 3/15/16, 5:20 AM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>>After this problem was discovered 4-6 months ago, we've been working on a
>>way to remedy it. We have a basic plan that William has suggested, but it
>>takes some time to work out how to implement it. So far, no one has had
>>the time needed to do this. It seems solvable with some effort.
>>My understanding is that SIP is a new security feature. Disabling it
>>leaves the Mac at the same level of security it has under Yosemite.
>>Michael
>>____________________
>>C. Michael Barton
>>Director, Center for Social Dynamics & Complexity
>>Professor of Anthropology, School of Human Evolution & Social Change
>>Head, Graduate Faculty in Complex Adaptive Systems Science
>>Arizona State University
>>voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>>fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
>>www:
>>https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7E
>>cmbarton&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28T
>>aiOmWcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=BMSNf4uJ_w2
>>ewwUgMTyEGQGU5wecIjrAaBpBY-3ebyA&e= ,
>>https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=CwIGaQ&
>>c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=D
>>u-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=nYM20vxBK7g_tQPNjML5LWX-szqTa
>>83D4p5P1fuat1o&e=
>>>> So it looks like this is actually the known problem with System
>>>> Integrity Protection. I hate to turn off a security feature, and do
>>>> two reboots, to be able to run a single application. Has there been
>>>> any progress in getting this fixed?
>>> No - I have the feeling that the ones using GRASS on OS X are still
>>> avoiding upgrading to El Capitan, and the ones who have are out in the
>>> cold. I raised the issue several times already.
>>> I slowly really think the best would be to abandon GRASS on OS X and
>>> focus on setting up an official docker image which can be used on OS X,
>>> Windows and Linux.
>>> Please convince me otherwise.
>>> Cheers,
>>> Rainer
>>>> Thanks,
>>>> -- Adam
>>>> From: Adam Dershowitz <adershowitz at exponent.com>
>>>> Date: Monday, March 14, 2016 at 11:21 PM
>>>> To: Michael Barton <Michael.Barton at asu.edu>, grass-user grass-user
>>>> <grass-user at lists.osgeo.org>
>>>> Subject: Re: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>>>> wxPython (missing)
>>>> And, I just tried to run 6.4, which I still had installed, and it also
>>>> won¹t run, but with a different error:
>>>> Python 2.7.10 found.
>>>> Cleaning up temporary files ...
>>>> Starting GRASS ...
>>>> Traceback (most recent call last):
>>>> File
>>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
>>>> line 37, in <module>
>>>> from core import globalvar
>>>> File
>>>>"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/core/globalvar.
>>>>py",
>>>> line 74, in <module>
>>>> import wx
>>>> File
>>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/__init__.py",
>>>> line 45, in <module>
>>>> from wx._core import *
>>>> File
>>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py",
>>>> line 4, in <module>
>>>> import _core_
>>>> ImportError: dlopen
>>>> (/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so,
>>>> 2): Library not loaded:
>>>> /Users/Shared/unix/wxpython-cocoa-lion/lib/libwx_osx_cocoau-3.0.dylib
>>>> Referenced from:
>>>> Reason: image not found
>>>> Error in GUI startup. If necessary, please
>>>> report this error to the GRASS developers.
>>>> Switching to text mode now.
>>>> Hit RETURN to continue...
>>>> Has anyone had any luck running GRASS on 10.11 at all?
>>>> -- Adam
>>>> From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of
>>>> Date: Monday, February 15, 2016 at 3:24 PM
>>>> To: grass-user grass-user <grass-user at lists.osgeo.org>
>>>> Subject: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>>>> wxPython (missing)
>>>> The packaging seems to have gone awry. I've been out of the country
>>>> and then sick since returning. Once I get well enough to get to the
>>>> office, I'll try and fix this.
>>>> Michael
>>>> C. Michael Barton
>>>> www:
>>>>7Ecmbarton&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbc
>>>>o28TaiOmWcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=BMSNf
>>>>4uJ_w2ewwUgMTyEGQGU5wecIjrAaBpBY-3ebyA&e= ,
>>>>Q&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM
>>>>&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=nYM20vxBK7g_tQPNjML5LWX
>>>>-szqTa83D4p5P1fuat1o&e=
>>>>    On Feb 15, 2016, at 12:59 PM, grass-user-request at lists.osgeo.org
>>>>    wrote:
>>>>    From: gene <martin.laloux at gmail.com>
>>>>    wxPython (missing)
>>>>    Date: February 15, 2016 at 11:55:37 AM MST
>>>>    To: <grass-user at lists.osgeo.org>
>>>>    With the 7.0.3 version of GRASS GIS on the Mac (M.Barton)
>>>><https://urldefense.proofpoint.com/v2/url?u=http-3A__grassmac.wikidot.co
>>>>m_&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOm
>>>>Wcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=BLKBXGdNzoj5N
>>>>WVFeIdX9twiagfusrChsptuGoEor-A&e= > I can only launch GRASS-7.0.app
>>>>    (7.0.3) in
>>>>    text mode.
>>>>    When I try to launch the App or use g.gui wxpython in the Grass
>>>>    shell the
>>>>    error is:
>>>>    "Launching <wxpython> GUI in the background, please waitŠ
>>>>    ERROR: wxGUI requires wxPython. No module named wxversion
>>>>    In the 7.0.2 version, wxPython is installed in
>>>>    /Applications/GRASS-7.0.app/Contents/MacOS/etc/python (wx,
>>>>    wxpython and
>>>>    pyparsing.py and wxversion.py) and it works.
>>>>    But none of these files/folders exist in the same folder of the
>>>>    7.0.3
>>>>    version
>>>>    Compilation error ?
>>>>    The size of the zip files are also different (80.19 and 83.89 for
>>>>    GRASS 7.01
>>>>    and GRASS 7.02, 35 .12 for GRASS 7.03)
>>>>    Many thanks
>>>> _______________________________________________
>>>> grass-user mailing list
>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mail
>>>>man_listinfo_grass-2Duser&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXa
>>>>bRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_
>>>>8z3v6Ks&s=sBt6fkr01Z2DicvtCKZ0pui9SLbC9JKsQfHXN6pMqcA&e=
>>> Rainer M. Krug
>>> email: Rainer<at>krugs<dot>de
>>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/cc178d26/attachment.sig>
