[GRASS-user] Invalid map size
Anna Petrášová kratochanna at gmail.com
Tue Mar 15 11:12:32 PDT 2016
On Tue, Mar 15, 2016 at 1:28 PM, Marvin Eng <knot.tyer at gmail.com> wrote:
> I was running winGRASS 7.0.0
> I don't know what I did but; now when I launch the GUI I get no monitor
> and a command console message saying:
> Invalid map size 142,0
> I installed winGRASS 7.0.3 and launched the GUI and I get the same message.
> I can get a monitor to open using d.mon start=wx0 in a command layer but
> when I do that the layer manager stops responding. When I close the monitor
> (with the x) and go back to the command console there is the following
> message:
> ERROR: Rendering failed. Details: Error reading PPM file
> I can 'work around' this with the "Start new map display" button and
> closing display 1 - but this is a bit annoying and will require me to redo
> all my workspace files.
I've seen this happening before. Open your workspace in a text editor and
look what you have in tag display, attribute dim. You might have some
exceptionally large values there. This seems to appear only on Windows when
you save your workspace while the map window is minimized. You can edit
this value and put some normal value in there (like 300), save it and try
to reload it again.
Anna
> Marvin Eng
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/5a758210/attachment.html>
