[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Rainer M Krug Rainer at krugs.de
Tue Mar 15 12:06:33 PDT 2016
Adam Dershowitz <adershowitz at exponent.com> writes:
> I don’t see an option to do that.  The portfile has a few variants, but
> nothing related to the gui.
OK - but it is interesting, that GRASS does actually compile and install
successfully - see the email from William.
> -- Adam
>>> I use Macports for a  bunch of other things (and Homebrew is
>>>incompatible
>>> with Macports)   So, I figured that I would just tried to install grass7
>>> using macports.  It does seem to install, but the gui doesn’t work:
>>>  $grass70
>>> Cleaning up temporary files...
>>> Starting GRASS GIS...
>>> ERROR: wxGUI requires wxPython. No module named wxversion
>>> Error in GUI startup. If necessary, please report this error to the
>>>GRASS
>>> developers.
>>> Switching to text mode now.
>>I don't use MacPorts - but can you try to install without GUI?
>>> Hit RETURN to continue...
>>> This is odd, since wxpython is installed.
>>> But, it seems like this is a different problem.
>>> -- Adam
>>> On 3/15/16, 9:50 AM, "Rainer M Krug" <Rainer at krugs.de> wrote:
>>>>Michael Barton <Michael.Barton at asu.edu> writes:
>>>>> The reason is that I (and William) package some key dependencies with
>>>>> the binary. The most important is wxPython, which is required by the
>>>>> GUI. If a user does not have exactly the same version of wxPython used
>>>>> to compile the binary, the GUI will fail. Making this more complicated
>>>>> is the fact that the only versions of wxPython that work completely
>>>>> correctly with Mac GRASS are 32 bit. But some other components are 64
>>>>> bit. This means that I need to compile GRASS with 32/64 bit dual
>>>>> architecture. So this is a consequence of making binaries that run on
>>>>> anyone's Mac (except the newest system with SIP enabled).
>>>>OK - so if I understand you correctly, installing via homebrew, should
>>>>not be that difficult, as GRASS is compiled for a specific wxPython -
>>>>correct?
>>>>> Michael
>>>>> ____________________
>>>>> C. Michael Barton
>>>>> Director, Center for Social Dynamics & Complexity
>>>>> Professor of Anthropology, School of Human Evolution & Social Change
>>>>> Head, Graduate Faculty in Complex Adaptive Systems Science
>>>>> Arizona State University
>>>>> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>>>>> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>>>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>>>>     On Mar 15, 2016, at 3:14 PM, Carlos Grohmann
>>>>>     <carlos.grohmann at gmail.com> wrote:
>>>>>     I run GRASS on OSX El Capitan (with SIP disabled). I don't think
>>>>>     that setting up a CLI-only version would be a solution as well. As
>>>>>     Rainer said, other software runs natively (see QGIS) and they
>>>>>     don't have any problems with OSX/SIP. We should look into that.
>>>>>     I don't understand why GRASS is offending SIP. Perhaps we should
>>>>>     seek out for help from others. Maybe Apple itself.
>>>>>     One point is that we need to disable SIP for the binary provided
>>>>>     by Michael Barton, but not if you compile it from source (or using
>>>>>     homebrew), so this could be fixable by changing paths, like Adam
>>>>>     suggested. Homebrew uses /usr/local, why can't we?
>>>>>     best
>>>>>     Carlos
>>>>>     On Tue, Mar 15, 2016 at 9:51 AM, Adam Dershowitz
>>>>>     <adershowitz at exponent.com> wrote:
>>>>>     Yes, SIP is a new security feature that prevents any applications
>>>>>         from
>>>>>         writing to a few key OS paths. I believe that it really is
>>>>>         that simple.
>>>>>         (see: https://support.apple.com/en-us/HT204899 )
>>>>>         Which, does beg the questionŠwhy does running GRASS require
>>>>>         writes to any
>>>>>         of these folders? That suggests that GRASS is doing something
>>>>>         that it
>>>>>         shouldn¹t be doing. Why should it be writing to system folders
>>>>>         at all at
>>>>>         runtime?
>>>>>         It is the only application that I have run into that has any
>>>>>         problems with
>>>>>         SIP. It would seem that this should be an easy fix. (for
>>>>>         example just
>>>>>         use /usr/local instead of /usr, or whatever the problem folder
>>>>>         is).
>>>>>         -- Adam
>>>>>     Prof. Carlos Henrique Grohmann
>>>>>     Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>>>>     - Digital Terrain Analysis | GIS | Remote Sensing -
>>>>>     http://carlosgrohmann.com
>>>>>     http://orcid.org/0000-0001-5073-5572
>>>>>     ________________
>>>>>     Can’t stop the signal.
>>>>Rainer M. Krug
>>>>email: Rainer<at>krugs<dot>de
>>>>PGP: 0x0F52F982
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>Rainer M. Krug
>>PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/4b07b7a4/attachment.sig>
