[GRASS-user] Invalid map size
Marvin Eng knot.tyer at gmail.com
Tue Mar 15 14:21:46 PDT 2016
Anna
Thank you again. That worked.
The "Save current window layout as default" box was checked - but I hit the
save button at the bottom of the page and now the GUI opens an monitor when
it starts up.
p.s. in winGRASS 7.0.3 the "GUI Settings" are accessed through the last
selection in the "Settings" menu which is labeled "Preferences" (although
the window that this selection opens is called "GUI Settings"
marvin
On Tue, Mar 15, 2016 at 1:20 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, Mar 15, 2016 at 4:05 PM, Marvin Eng <knot.tyer at gmail.com> wrote:
>> Anna:
>> Your solution worked fine for the offending workspace file (*.gxw).
>> It had
>> display name="Display 1" . . . .  dim="-32000,-32000,160,39"
>> I changed that to 300 all round and I am now able to use that gxw with
>> display 1.
>> However, I seem to have broken something more basic. No matter how I
>> start the GRASS GUI (in demolocation or a newly created location or any of
>> my other locations) I get the same "Invalid map size" message and there is
>> no monitor.
>> Is there another 'workspace file' for the start up of GRASS that I should
>> be looking for to edit?
> I think it might be in your settings. Open the workspace which works for
> you now and go to GUI settings, check (or leave checked) Save current
> window layout as default in general tab and make sure you don't have any
> GRASS window minimized and then Save. Try to launch GRASS and it should
> work again. I fixed some of these things quite recently, I would have to
> check all the use cases again to see if it persists in the recent version.
> Anna
>> marvin
>> On Tue, Mar 15, 2016 at 11:12 AM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>>> Hi,
>>> On Tue, Mar 15, 2016 at 1:28 PM, Marvin Eng <knot.tyer at gmail.com> wrote:
>>>> I was running winGRASS 7.0.0
>>>> I don't know what I did but; now when I launch the GUI I get no monitor
>>>> and a command console message saying:
>>>> Invalid map size 142,0
>>>> I installed winGRASS 7.0.3 and launched the GUI and I get the same
>>>> message.
>>>> I can get a monitor to open using d.mon start=wx0 in a command layer
>>>> but when I do that the layer manager stops responding. When I close the
>>>> monitor (with the x) and go back to the command console there is the
>>>> following message:
>>>> ERROR: Rendering failed. Details: Error reading PPM file
>>>> I can 'work around' this with the "Start new map display" button and
>>>> closing display 1 - but this is a bit annoying and will require me to redo
>>>> all my workspace files.
>>> I've seen this happening before. Open your workspace in a text editor
>>> and look what you have in tag display, attribute dim. You might have some
>>> exceptionally large values there. This seems to appear only on Windows when
>>> you save your workspace while the map window is minimized. You can edit
>>> this value and put some normal value in there (like 300), save it and try
>>> to reload it again.
>>> Anna
>>>> Marvin Eng
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/a0209ee9/attachment.html>
