[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Adam Dershowitz adershowitz at exponent.com
Wed Mar 16 06:11:37 PDT 2016
On 3/16/16, 9:03 AM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>I've held off updating to make sure I could continue to provide binaries
>for the GRASS community. If you are right, I will upgrade one of my
>computers to the new OS and try this. SIP off and compile.
I hope that will work. But, I did just try to install your binaries
without SIP, then reenabled and it failed to run.  Hopefully, your rebuild
will fix it.
FYI, I do really appreciate that you provide the binaries!  Thank you.
>The question then is whether users need to turn SIP off to install in the
>normal applications folder.
No, they don’t.  The vast majority of applications have not had any
problems transitioning to SIP.  The only exceptions that I have heard of
having any problems are an application that tries to do some low-level
finder stuff (so it actually could be considered a real security risk) and
GRASS.  Although, my sampling is far from complete!
>Michael
>____________________
>C. Michael Barton
>Director, Center for Social Dynamics & Complexity
>Professor of Anthropology, School of Human Evolution & Social Change
>Head, Graduate Faculty in Complex Adaptive Systems Science
>Arizona State University
>voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
>www:
>https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7E
>cmbarton&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28T
>aiOmWcn6rCn8wM&m=8a8vJwN3CLQA76SAkEtMdsfp_z-HB2Vqa_5GDDVCFJs&s=brH8l8fvJcn
>BOtKN-Iit46NVfqgp0TIE-1AzhSS-BOs&e= ,
>https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=CwIGaQ&
>c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=8
>a8vJwN3CLQA76SAkEtMdsfp_z-HB2Vqa_5GDDVCFJs&s=4QJPzCYG_0w7Wr4CmDr_AQ1GzmaYY
>SRUHhN3ywKiNnk&e=
>> On Mar 16, 2016, at 12:24 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Rainer M Krug <Rainer at krugs.de> writes:
>>> Adam Dershowitz <adershowitz at exponent.com> writes:
>>>> Got it.  Now, based on that, I have found it.  Apparently, it is for
>>>> protected processes:
>>>>https://urldefense.proofpoint.com/v2/url?u=https-3A__developer.apple.co
>>>>m_library_mac_documentation_Security_Conceptual_S&d=CwIGaQ&c=t0wRGL5ICV
>>>>zH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=8a8vJwN3CL
>>>>QA76SAkEtMdsfp_z-HB2Vqa_5GDDVCFJs&s=lpyQ9k04zOgM7WEr5IuYKSvzyOXTxIPvKFF
>>>>p5HLGOCU&e=
>>>>ystem_Integrity_Protection_Guide/RuntimeProtections/RuntimeProtections.
>>>>html
>>> Which seems to be the reason why during the make step (make is in
>>> /usr/bin, therefore a protected binary), the DYLD_LIBRARY_PATH is
>>> ignored.
>>> But when running GRASS, it should work.
>>> Has anybody tried out to
>>> 1) disable SIP
>>> 2) compile GRASS from source
>>> 3) install GRASS
>>> 4) enable SIP
>>> and does it run?
>> Just tried it out, ant it works. So the DYLD_LIBRARY_PATH issue only
>> affects the compilation / installation of GRASS.
>>> Do you know if Macports uses an own make (and possibly other tools?),
>>>or
>>> the one supplied by OS X?
>>>> So, would it be possible to just just the paths that are used for the
>>>> search paths in the Application bundle itself?
>>>> -- Adam
>>>> On 3/15/16, 4:43 PM, "William Kyngesburye" <woklist at kyngchaos.com>
>>>>wrote:
>>>>> GRASS does not write to those SIP-restricted locations.
>>>>> From what I've read, SIP also causes apps to ignore
>>>>>DYLD_LIBRARY_PATH, no
>>>>> matter where it points to.  And the errors that have been reported
>>>>>point
>>>>> to it as well.
>>>>>> On Mar 15, 2016, at 3:06 PM, Adam Dershowitz
>>>>>> wrote:
>>>>>> On 3/15/16, 3:37 PM, "grass-user on behalf of William Kyngesburye"
>>>>>> <grass-user-bounces at lists.osgeo.org on behalf of
>>>>>> wrote:
>>>>>>> On Mar 15, 2016, at 2:05 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>>>>>>>> William Kyngesburye <woklist at kyngchaos.com> writes:
>>>>>>>>> This is also a known issue, related to but separate from the
>>>>>>>>> packaging
>>>>>>>>> issue.  During compilation, GRASS also uses DYLD_LIBRARY_PATH to
>>>>>>>>>find
>>>>>>>>> the in-compilation copies of the libraries so it can run the
>>>>>>>>>modules
>>>>>>>>> to create the help files.
>>>>>>>> OK - this aligns with what I guessed from the error messages.
>>>>>>>> So the  DYLD_LIBRARY_PATH is only used during compilation - and
>>>>>>>>not
>>>>>>>> during execution, even without "make install"?
>>>>>>> No, DYLD_LIBRARY_PATH is also used during execution, that's what's
>>>>>>> causing trouble in the app bundling.
>>>>>>>>> The packaging issue with DYLD_LIBRARY_PATH can be fixed in
>>>>>>>>>packaging
>>>>>>>>> so that everything within the GRASS app package looks directly
>>>>>>>>>inside
>>>>>>>>> the package for libraries and not rely on DYLD_LIBRARY_PATH.
>>>>>>>>> Homebrew, Macports and /usr/local builds don't need to worry
>>>>>>>>>about it
>>>>>>>>> because the extra dependencies that are bundled in the app are
>>>>>>>>> already
>>>>>>>>> in their proper place.
>>>>>>>> OK - so in homebrew (I can't speak for Macports) the issue is at
>>>>>>>>the
>>>>>>>> moment only the one you discuss below.
>>>>>>>>> The compilation issue needs work to compile all libraries with
>>>>>>>>>the
>>>>>>>>> temporary path inside the libraries and modules (this part is
>>>>>>>>>easy)
>>>>>>>>> so
>>>>>>>>> that during compilation help file generation works.
>>>>>>>> OK - so can you give me any suggestions how I can solve this to
>>>>>>>>make
>>>>>>>> GRASS at least compile on homebrew?
>>>>>>>> Speaking generally - is this really the right approach to take,
>>>>>>>>i.e.
>>>>>>>> use
>>>>>>>> the generated binaries to generate the help files during
>>>>>>>>installation?
>>>>>>>> Wouldn't it be much easier to do this during installation?
>>>>>>> Well, the compilation approach is how it's been done as long as I
>>>>>>>can
>>>>>>> remember, it's nothing specific to OS X.  Changing this would be
>>>>>>>major.
>>>>>>>>> And then during installation change all the embedded library
>>>>>>>>>paths to
>>>>>>>>> the final destination (this is harder, to figure out the complex
>>>>>>>>> makefile include system of GRASS to get this operation in the
>>>>>>>>>right
>>>>>>>>> place).
>>>>>>>> The paths are in the grass script file? Or in others as well?
>>>>>>> No, the paths are embedded in the libraries and binary executables.
>>>>>>>> Wouldn't it make sense to
>>>>>>>> 1) split the generation of the help files from the build step
>>>>>>>>into a
>>>>>>>> separate make target
>>>>>>>> 2) call the make target for help pages as a last step in the
>>>>>>>>install
>>>>>>>> step?
>>>>>>>> This might make packaging more difficult, but wouldn't it make the
>>>>>>>> whole
>>>>>>>> process clearer?
>>>>>>>>> Homebrew, Macports, /usr/local AND app installs do have a problem
>>>>>>>>> with
>>>>>>>>> this.
>>>>>>>> It worked with Yosemite without problems. So this only needs to be
>>>>>>>> done,
>>>>>>>> because of the issues you describe above?
>>>>>>> It's specifically an El Capitan+ issue, because of SIP.
>>>>>> I wonder if you can explain this anymore.  Because, it is not at all
>>>>>> clear
>>>>>> to me.  DYLD_LIBRARY_PATH is something that is used all the time and
>>>>>> works
>>>>>> fine in El Capitan for most Applications.  The only thing that SIP
>>>>>> provides, if I understand correctly, is that it is not possible for
>>>>>>an
>>>>>> application to write to /System /bin /sbin or /usr (and a few Apple
>>>>>> specifics in /Applications).  Writing to /usr/local and /usr/lib
>>>>>>should
>>>>>> be
>>>>>> OK.  Just having all the different versions of libraries around, and
>>>>>> dynamically finding them should work fine.
>>>>>> So, during run time, why does GRASS attempt to write to /usr (or
>>>>>>one of
>>>>>> the other Apple owned folders?  If it is using DYLD_LIBRARY_PATH to
>>>>>>find
>>>>>> the necessary libraries from within the GRASS bundle, there should
>>>>>>be no
>>>>>> need to write there.
>>>>>> Is it doing something unusual, such as at startup it tries to copy
>>>>>>a few
>>>>>> files from the bundle to /usr so that it doesn¹t have to change
>>>>>> DYLD_LIBRARY_PATH?  Even if that is the case, just changing those
>>>>>>paths
>>>>>> to
>>>>>> /usr/local would solve the SIP problem.
>>>>>> If the problem relates to how GRASS finds the correct version of
>>>>>> libraries, at least as a work around, it should be possible to use
>>>>>> install_name_tool to point to the correct version of libraries for
>>>>>>any
>>>>>> specific build.  This is what I first attempted, but just fixing one
>>>>>> library didn¹t do the job for me, as it then triggered another
>>>>>>problem.
>>>>>> So, I really don¹t understand what it is that GRASS does, at
>>>>>>runtime,
>>>>>> that
>>>>>> SIP objects to.
>>>>>>>>> It works for Michael (and me) for the "official" packages
>>>>>>>>>because we
>>>>>>>>> compile on older systems that don't have SIP.
>>>>>>>> Thanks for these clarifications.
>>>>>>>> I would very much appreciate if we could see to get the
>>>>>>>>compilation
>>>>>>>> and
>>>>>>>> installation working using homebrew so that there is at least one
>>>>>>>>way
>>>>>>>> of
>>>>>>>> t=running GRASS on El Capitan without having to interfere with the
>>>>>>>> security settings.
>>>>>>>> Thanks,
>>>>>>>> Rainer
>>>>>>>>>> On Mar 15, 2016, at 11:39 AM, Rainer M Krug <Rainer at krugs.de>
>>>>>>>>>>wrote:
>>>>>>>>>> I tried again to install 7.1 head without GUI using homwbrew,
>>>>>>>>>>and I
>>>>>>>>>> get
>>>>>>>>>> the following error:
>>>>>>>>>> | bash-4.3$ less
>>>>>>>>>> /Users/rainerkrug/Library/Logs/Homebrew/grass-71/02.make
>>>>>>>>>> | bash-4.3$ cd
>>>>>>>>>> /private/tmp/grass-7120160315-47344-1ybn5ar/scripts/d.rast.leg
>>>>>>>>>> | bash-4.3$ ls
>>>>>>>>>> | Makefile        d.rast.leg.html d.rast.leg.py
>>>>>>>>>> | bash-4.3$ make
>>>>>>>>>> | if [
>>>>>>>>>>"/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-da
>>>>>>>>>>rwin
>>>>>>>>>> 15
>>>>>>>>>> .3.0/scripts/d.rast.leg"
>>>>>>>>>> | != "" ] ; then
>>>>>>>>>>GISRC=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-app
>>>>>>>>>>le-d
>>>>>>>>>> ar
>>>>>>>>>> win15.3.0/demolocation/.grassrc71
>>>>>>>>>>GISBASE=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-a
>>>>>>>>>>pple
>>>>>>>>>> -d
>>>>>>>>>> arwin15.3.0
>>>>>>>>>>PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-app
>>>>>>>>>>le-d
>>>>>>>>>> ar
>>>>>>>>>>win15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x8
>>>>>>>>>>6_64
>>>>>>>>>> -a
>>>>>>>>>>pple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar
>>>>>>>>>>/dis
>>>>>>>>>> t.
>>>>>>>>>> x86_64-apple-darwin15.3.0/scripts:$PATH"
>>>>>>>>>>PYTHONPATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_
>>>>>>>>>>64-a
>>>>>>>>>> pp
>>>>>>>>>>le-darwin15.3.0/etc/python:/private/tmp/grass-7120160315-47344-1y
>>>>>>>>>>bn5a
>>>>>>>>>> r/
>>>>>>>>>> dist.x86_64-apple-darwin15.3.0/gui/wxpython:$PYTHONPATH"
>>>>>>>>>>DYLD_LIBRARY_PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/di
>>>>>>>>>>st.x
>>>>>>>>>> 86
>>>>>>>>>>_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1y
>>>>>>>>>>bn5a
>>>>>>>>>> r/
>>>>>>>>>>dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-
>>>>>>>>>>4734
>>>>>>>>>> 4-
>>>>>>>>>>1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts:/private/tmp/grass
>>>>>>>>>>-712
>>>>>>>>>> 01
>>>>>>>>>>60315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:/private/t
>>>>>>>>>>mp/g
>>>>>>>>>> ra
>>>>>>>>>> ss-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:"
>>>>>>>>>> | LC_ALL=C
>>>>>>>>>>/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-dar
>>>>>>>>>>win1
>>>>>>>>>> 5.
>>>>>>>>>> | --html-description < /dev/null | grep -v '</body>\|</html>' >
>>>>>>>>>> | d.rast.leg.tmp.html ; fi
>>>>>>>>>> | dyld: Library not loaded:
>>>>>>>>>>/usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7.
>>>>>>>>>>1.sv
>>>>>>>>>> n.
>>>>>>>>>> dylib
>>>>>>>>>> |   Referenced from:
>>>>>>>>>>win1
>>>>>>>>>> 5.
>>>>>>>>>> 3.0/bin/g.parser
>>>>>>>>>> |   Reason: image not found
>>>>>>>>>> | make: *** [d.rast.leg.tmp.html] Error 1
>>>>>>>>>> | rm d.rast.leg.tmp.html
>>>>>>>>>> | bash-4.3$
>>>>>>>>>> In other words: grass is looking during the compilation for a
>>>>>>>>>> dynamic
>>>>>>>>>> library
>>>>>>>>>>(/usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7
>>>>>>>>>>.1.s
>>>>>>>>>> vn
>>>>>>>>>> .dylib)
>>>>>>>>>> which has been created, but will only be there when installing.
>>>>>>>>>> Also important: this error only occurs when the html manual
>>>>>>>>>>pages
>>>>>>>>>> are
>>>>>>>>>> created!
>>>>>>>>>> Cheers,
>>>>>>>>>> Rainer
>>>>>>>>>>>> I use Macports for a  bunch of other things (and Homebrew is
>>>>>>>>>>>> incompatible
>>>>>>>>>>>> with Macports)   So, I figured that I would just tried to
>>>>>>>>>>>>install
>>>>>>>>>>>> grass7
>>>>>>>>>>>> using macports.  It does seem to install, but the gui doesn¹t
>>>>>>>>>>>> work:
>>>>>>>>>>>> $grass70
>>>>>>>>>>>> Cleaning up temporary files...
>>>>>>>>>>>> Starting GRASS GIS...
>>>>>>>>>>>> ERROR: wxGUI requires wxPython. No module named wxversion
>>>>>>>>>>>> Error in GUI startup. If necessary, please report this error
>>>>>>>>>>>>to
>>>>>>>>>>>> the
>>>>>>>>>>>> GRASS
>>>>>>>>>>>> developers.
>>>>>>>>>>>> Switching to text mode now.
>>>>>>>>>>> I don't use MacPorts - but can you try to install without GUI?
>>>>>>>>>>>> Hit RETURN to continue...
>>>>>>>>>>>> This is odd, since wxpython is installed.
>>>>>>>>>>>> But, it seems like this is a different problem.
>>>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__www.kyngchaos.co
>>>>>>>m_&d
>>>>>>> =C
>>>>>>>wIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWc
>>>>>>>n6rC
>>>>>>> n8
>>>>>>>wM&m=r1HkNs7RjOpSnmLwmP3Cs2L1e3PUB46Ip-W1bup-rFc&s=4w5wYepEPeebD54T1
>>>>>>>h_V7
>>>>>>> mJ
>>>>>>> Bf8t6V3mbREBfgUP8u90&e=
>>>>>>> "Oh, look, I seem to have fallen down a deep, dark hole.  Now what
>>>>>>>does
>>>>>>> that remind me of?  Ah, yes - life."
>>>>>>> - Marvin
>>>>>>> _______________________________________________
>>>>>>> grass-user mailing list
>>>>>>> grass-user at lists.osgeo.org
>>>>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_
>>>>>>>mail
>>>>>>> ma
>>>>>>>n_listinfo_grass-2Duser&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGq
>>>>>>>XabR
>>>>>>> Lt
>>>>>>>SzGmh8YEvbco28TaiOmWcn6rCn8wM&m=r1HkNs7RjOpSnmLwmP3Cs2L1e3PUB46Ip-W1
>>>>>>>bup-
>>>>>>> rF
>>>>>>> c&s=Wvr4pv5ar3OjaTpiOn-UaLvVb2_IFgxGgKN0IHHRSXo&e=
>>>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_m
>>>>>>ailm
>>>>>>an_listinfo_grass-2Duser&d=CwIFaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGq
>>>>>>XabR
>>>>>>LtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=wBZVhJR1Vijar8vPd0vMw-5LMplYPnRZhF_
>>>>>>TOf4
>>>>>> CZvY&s=dFMvzAURv7ExJqKWuHhJuiWSp1tVxWAQLXdLERfRUcY&e=
>>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__www.kyngchaos.com_
>>>>>&d=C
>>>>>wIFaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6
>>>>>rCn8
>>>>>wM&m=wBZVhJR1Vijar8vPd0vMw-5LMplYPnRZhF_TOf4CZvY&s=GvawdpD6TkYdZwsdpwj
>>>>>Ww1t
>>>>> 6syI0zj0Ou2szNtTSNWQ&e=
>>>>> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
>>>>> - Marvin
>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mai
>>>>lman_listinfo_grass-2Duser&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGq
>>>>XabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=8a8vJwN3CLQA76SAkEtMdsfp_z-HB2Vqa
>>>>_5GDDVCFJs&s=zeHh0C0suAsouujRlhHjO0snRjDR9Ga2pfaXnh60h0E&e=
>> Rainer M. Krug
>> email: Rainer<at>krugs<dot>de
>> PGP: 0x0F52F982
