[GRASS-user] select areas
Veronica Andreo veroandreo at gmail.com
Sat Mar 19 14:07:13 PDT 2016
Hello Daniel,
What about using operator=contains and -r flag? Does that work?
You may also want to update to GRASS 7. Check the manual for v.select [0]
there, it has been improved a lot with examples for most (if not all)
operators
Best,
Vero
[0] https://grass.osgeo.org/grass70/manuals/v.select.html
2016-03-19 5:39 GMT-03:00 Daniel Torres <nobeeakon at gmail.com>:
> Hi everybody,
> I want to select areas that don't overlap with points, using "v.select -r
> [...] operator=overlap",  I get unclosed boundaries and centroids at the
> places where an area is neighbour of a selected area. I do not understand
> how to obtain also the common border so to obtain closed boundaries with
> centroids (areas). I'm using GRASS 6.4, and imported the map of areas from
> a shapefile...
> Thanks, and sorry for the simple question.
> Daniel
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160319/5d2cccab/attachment.html>
