[GRASS-user] GRASS GIS i.atcorr for aerial data
kameswari devi kams.devi at gmail.com
Thu May 5 22:05:08 PDT 2016
Hello
i have customized i.atcorr module for satellite sensors of altitude
800kms.It is working properly.i want to find out whether Grass GIS i.atcorr
module be customized for Aerial sensor?
Attempted for Aerial sensor which has altitude of 13km but module failed.if
the satellite altitude is above  100 km in the icnd file, module is working
also if the it is given as positive number also working.If it is below
100km not working by saying"wavelength below 0.25nm." Is there any
limitation for the satellite altitude in icnd file.may i know whether
i.atcorr supports to Aerial data or not? is anybody used  AVIRIS  for grass
atmospheric correction.
*Regardskameswari devi P*
*Scientist-C*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160506/70d9346a/attachment.html>
