[GRASS-user] r.to.vect.lines addon not working
Markus Neteler neteler at osgeo.org
Fri May 6 09:55:23 PDT 2016
On May 6, 2016 6:37 PM, "Carlo Cormio" <carlo.cormio at gmail.com> wrote:
> MMMh, maybe I'm making a mess ...
> I "make distclean" my GRASS GIS build, updated svn (svn up) to r68383,
then compiled and make, but it says it's r68381.
> Do I have to make something different to compile and install the righr
revision?!
Just g.extension r....
Markus
> Thanks,
> Carlo
> Il 06/05/2016 16:57, Markus Neteler ha scritto:
>> On 5/6/16, Martin Landa <landa.martin at gmail.com> wrote:
>>> Hi,
>>> 2016-05-06 15:59 GMT+02:00 Carlo Cormio <carlo.cormio at gmail.com>:
>>>> ALso XML Copy Editor analysis provides the same error message:
>>>> Error at line 17, column 26: not well-formed (invalid token)
>>> it seems to be here:
>>>          <gisprompt age=""old" element="cell" prompt="raster";" />
>>> the correct form is:
>>>          <gisprompt age="old" element="cell" prompt="raster" />
>> Fixed in r68382. Two wrong ";" chars removed (I suppose a leftover
>> from the related C syntax while this is Python).
>> Carlo, please try again.
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160506/50032472/attachment.html>
