[GRASS-user] Dissolve polygones from layer1 witch intersect with polygones of layer2
Mounirsky kaizersozy at gmail.com
Tue Nov 29 07:01:37 PST 2016
I'm trying to automatize geoprocessing tools using grass command lines in a
python script,
so in the case of an isolate polygon (don't overlap) it will not be added in
may original vector... !
I want it to work in any case and because I'm ruining command lines so I
can't make tests (overlaps or not) !
Any idea ?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Dissolve-polygons-from-layer1-witch-overlaps-with-polygons-of-layer2-tp5297681p5297873.html
Sent from the Grass - Users mailing list archive at Nabble.com.
