[GRASS-user] Question on memory allocation and use
Moritz Lennert mlennert at club.worldonline.be
Sat Oct 1 04:44:23 PDT 2016
On 23/09/16 20:51, Rich Shepard wrote:
> On Fri, 23 Sep 2016, Markus Metz wrote:
>> Apparently there are less than 52 MB of free memory left. The resulting
>> vector contours must be quite large. Try to export GRASS_VECTOR_LOWMEM=1
>> before running r.contour.
>> Maybe also use a larger step or less levels.
>   Took a different approach by reducing the size of the source DEMs (which
> cover a very large area compared to the area of interest).
>   Using v.to.rast I converted the project boundary vector to a raster file,
> then made it into a mask with r.mask. The mask then limited the area of the
> source DEMs with g.copy.
FYI: Since GRASS 7 r.mask actually has a vector= parameter which allows
setting the mask directly from a vector map.
>   Now re-running r.contour on the bare earth DEM; it should easily fit into
> the 4G RAM on this host.
> Thanks, Markus,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
