[GRASS-user] Specifying wxPython version at grass start [RESOLVED]
Rich Shepard rshepard at appl-ecosys.com
Sat Sep 3 11:04:46 PDT 2016
On Sat, 3 Sep 2016, Rich Shepard wrote:
>  I added a couple of print statements; 7.2 is compiling now.
   But these did not display after building.
>> Also check if you have GRASS_WXVERSION defined, you don't need to
>> define when you run the default version.
>  No GRASS_WXVERSION defined.
   Oops! There is GRASS_WXVERSION exported in ~/.bash_profile, but it's a
much earlier version. Exporting the correct version on the command line
allows both 7.2 and 7.3 to load.
   So, why is the source code not picking up the correct version but does
correctly use the environment variable? An answer now is not necessary, but
I'd be curious to learn the answer at some point.
Much appreciated, Anna,
Rich
