[GRASS-user] Grass 7 and postgresql
patrick s. patrick_gis at gmx.net
Mon Sep 5 00:41:21 PDT 2016
Running PG connection on grass70 works for me as well.
Wild guess:
1.) Are the maps stored in Schemas? (see $INPATH below)
2.) Have you tested the change/removing of quotations? (see codeexample below)
My (tested) code in BASH:
GSCHEMA=grass_2015
INPATH="PG:dbname=$DB_NAME active_schema=$ISCHEMA"
db.connect driver=pg database=psql_local schema=$GSCHEMA #no quotations here"
db.connect -p
v.in.ogr dsn="$INPATH" out=pt layer="xy" --overwrite #I use quotations here
On Sep 2, 2016 6:45 PM, "Nikos Alexandris"<nik at nikosalexandris.net>  wrote:
Patrick
Dr. Patrick Schirmer
Fahrländer Partner AG
>> GRASS 7.3.svn (wgs84):~ > db.tables -p
>> DBMI-PostgreSQL driver error:
>> Connection failed.
>> could not connect to server: No such file or directory
>>     Is the server running locally and accepting
>>     connections on Unix domain socket "/run/postgresql/.s.PGSQL.5432"?
> Can you connect with the psql command?
> Is the service reachable at port 5432?
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160905/5628cbdb/attachment.html>
