[GRASS-user] Exiting grass-7.x
Rainer M Krug Rainer at krugs.de
Thu Sep 8 09:02:41 PDT 2016
Vaclav Petras <wenzeslaus at gmail.com> writes:
> On Thu, Sep 8, 2016 at 9:28 AM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>  I'm curious about the difference in the two exit choice buttons displayed
>  when ctrl-q (or File->Quit) is used to exit grass. The dialog box asks "Do
>  you want to quit GRASS including shell prompt or just close the GUI?"
> One just ends the GUI process, the other ends the GUI, ends all the other GUIs and exits the whole GRASS GIS session.
>  When I click on the rightmost button (Quit GRASS GIS) the GUI displays but
>  the shell prompt remains.
> That's a bug.
>  It's no problem to type 'exit' at the prompt and return to the bash shell,
>  so I'm curious if the same behavior regardless of which choice (other than
>  cancel) is made is deliberate.
> It works for me on Ubuntu. The know issue is that it does not work on Mac OS X.
It does for me on El Capitan GRASS 7.04, 7.2 and 7.3 all installed via homebrew.
Cheers,
Rainer
> If you want to debug it: The whole system is based on sending signals and managed through GUI_PID and PID variables which you get from g.gisenv. It
> lives in the following files:
> gui/wxpython/lmgr/frame.py
> gui/wxpython/core/utils.py
> lib/init/grass.py
> Vaclav
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160908/2744b92a/attachment-0001.sig>
