[GRASS-user] qgis problems SL 7 (Processing); (http://courses.neteler.org/qgis-2-10-rpms-for-fedora-21-centos-7-scientific-linux-7/)
Vaclav Petras wenzeslaus at gmail.com
Thu Sep 8 15:57:12 PDT 2016
On Thu, Sep 8, 2016 at 3:21 PM, stephen sefick <ssefick at gmail.com> wrote:
>     os.path.join(pluginPath, 'ui', 'DlgResults.ui'))
>   File "/usr/lib64/python2.7/site-packages/PyQt4/uic/__init__.py", line
213, in loadUiType
>     exec(code_string.getvalue(), ui_globals)
>   File "", line 52, in
>   File "/usr/lib64/python2.7/site-packages/qgis/utils.py", line 478, in
_import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
> ImportError: No module named QtWebKit.QWebView
This looks like a problem in QGIS related to the QtWebKit dependency which
is recently problematic as far as I can tell from QGIS developer mailing
list. You can use GRASS GIS through the GRASS plugin or just use the
standalone GRASS GIS.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160908/877a9c4c/attachment.html>
