[GRASS-user] Raster renamed but d.rast does not find it
Rich Shepard
rshepard at appl-ecosys.com
Fri Sep 9 11:46:20 PDT 2016
GRASS-7.3. With 'g.rename rast=hdr,bare_earth_2010' I renamed the raster
file called 'hdr' to 'bare_earth_2010'.
In the console:
> g.list type=raster
bare_earth_2010
highest_hit_2010
shows the two renamed raster files.
Using the GUI I try to display bare_earth_2010 and the Layer Manager
console window displays:
Failed to run command 'd.rast map=hdr at topography'. Details:
GRASS_INFO_ERROR(4555,1): Raster map <hdr at topography> not found
GRASS_INFO_END(4555,1)
GRASS_INFO_ERROR(4556,1): Raster map <hdr at topography> not found
GRASS_INFO_END(4556,1)
GRASS_INFO_ERROR(4724,1): Raster map <hdr at topography> not found
GRASS_INFO_END(4724,1)
d.rast from the command line fails, too:
> d.rast map=bare_earth_2010
ERROR: Neither MONITOR (managed by d.mon command) nor
GRASS_RENDER_IMMEDIATE (used for direct rendering) defined
How do I correct this name mis-match?
Rich
