[GRASS-user] Vector maps with superimposed areas
Moritz Lennert mlennert at club.worldonline.be
Tue Sep 13 01:14:06 PDT 2016
Le Fri, 9 Sep 2016 16:07:39 +0000,
"Luna, Daniel Eduardo" <DEL47 at pitt.edu> a écrit :
> Hi!
> I'm working with a vector map with superimposed areas, and I'm using
> the module v.rast.stats with it, but it is not working for those
> areas that are completely behind bigger areas. You guys know how we
> can do this procedure?
This should actually not even exist in the GRASS vector format.
Overlapping areas should not exist. How did you create them ?
Moritz
