[GRASS-user] Importing data in .atx/.gdb format
Rich Shepard rshepard at appl-ecosys.com
Wed Sep 14 13:39:29 PDT 2016
On Wed, 14 Sep 2016, Markus Metz wrote:
> Using CLI, what is the output of v.in.ogr
> input=~/data/grassdata/or-trans/a00000001.gdbtable -l ?
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000001.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000001.gdbtable>
(format 'OpenFileGDB') contains 1 layers:
GDB_SystemCatalog
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000002.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000002.gdbtable>
GDB_DBTune
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000003.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000003.gdbtable>
GDB_SpatialRefs
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000004.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000004.gdbtable>
GDB_Items
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000005.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000005.gdbtable>
GDB_ItemRelationships
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000006.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000006.gdbtable>
GDB_ItemRelationshipTypes
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000007.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000007.gdbtable>
GDB_ItemTypes
> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000009.gdbtable -l
Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000009.gdbtable>
OR_Trans_for_Public_Distribution_8_2014
> This tells you only that the coordinate reference system of the input
> data is unknown. It might be Lat/Lon or something else. You can try to
> 1) import the data into a Lat/Lon location, reproject to the target
> location and check if the geolocation is ok
   Tried this without success.
> 2) ask the data provider about the coordinate reference system for
> this data source
   According to the metadata.xml file: the projection is Lambert Conformal Conic
stdparll-1 43.000000
stdparll-2 45.500000
longitude cm -120.500000
latprj 41.750000
cell res. 0.004096m (1 International feet)
North American Datum of 1983
   Which is very close to, but not exactly the same standard paralles as the
project location.
Rich
