[GRASS-user] Problems using i.worldview.toar
William Hudspeth bhudspeth at edac.unm.edu
Fri Sep 16 13:43:00 PDT 2016
Nikos,
Thank you very much for your assistance. Changing the file names worked,
as you suggested. I will now be able to move forward with my image
processing.
Thanks again...William
On 09/09/2016 06:12 PM, Nikos Alexandris wrote:
> William Hudspeth:
>>>> I am using i.worldview.toar with the latest version of GRASS 7.3. I
>>>> was
>>>> able to successfully download and install this extension. I have tried
>>>> using the module with the following input and error. All of the input
>>>> files exist, and I get an error stating that "No data base element
>>>> files
>>>> found". Help appreciated...
>>>> i.worldview.toar
>>>> band=worldview2_b1_RED at worldview2,worldview2_b2_GREEN at worldview2,worldview2_b3_BLUE at worldview2,worldview2_b4_NIR at worldview2
>>>> outputsuffix=toar utc=2010-04-11T18:07:06.558405Z doy=101 sea=60.3
> Nikos Alexandris:
>>> Do you really need the 'worldview2' prefix for your band names? It's
>>> identical to your Mapset's name. This is what a mapset is meant (or can
>>> be used) for: a set of maps.  In this case, it's a set of 'worldview2'
>>> "maps".
>>> Would you rename your bands and try again?
>>> i.worldview.toar band=b1_RED,b2_GREEN,b3_BLUE,b4_NIR outputsuffix=toar
> William Hudspeth:
>> I have given the bands simpler names, have re-run i.worldview.toar, and
>> am getting the same error:
>> i.worldview.toar
>> band=b1_red at worldview2,b2_green at worldview2,b3_blue at worldview2,b4_nir at worldview2
>> |! Using Day of Year to calculate Earth-Sun distance.
>> |! Region matching the b1_red at worldview2 spectral band
>> |* Processing the b1_red at worldview2 band
>> Traceback (most recent call last):
>>   File
>> "/home/wilbur/.grass7/addons/scripts/i.worldview.toar", line
>> 416, in <module>
>>     sys.exit(main())
>>   File
>> 320, in main
>>     acf = float(CF_BW_ESUN[band][2])
>> KeyError: 'b1_red'
>> WARNING: No data base element files found
> William,
> apologies for the inconvenience. I now had a better look and remember
> what is
> what. Comments from the code itself:
> Factors for Conversion to Top-of-Atmosphere Spectral Radiance
>    (absolute radiometric calibration factors)
> Structure of the dictionary:
> - Key: Name of band
> - Items in tupple(s):
>    - 1st: Absolute Calibration Factors
>    - 2nd: Spectral Band's Effective Bandwidth, Δλ
>    - 3rd: Band-Averaged Solar Spectral Irradiance [W/sq.m./micro-m]
> Retrieving values:
>    band = <Name of Band>
>    K[band][0]  # for Effective Bandwidth
>    K[band][1]  # for Esun
>    K[band][2]  # for Absolute Conversion Factor
> which are stored in the following python dictionary:
> CF_BW_ESUN = {
>    'Pan':     (0.28460000, 1580.8140, 0.056783450),
>    'Coastal': (0.04730000, 1758.2229, 0.009295654),
>    'Blue':    (0.05430000, 1974.2416, 0.012608250),
>    'Green':   (0.06300000, 1856.4104, 0.009713071),
>    'Yellow':  (0.03740000, 1738.4791, 0.005829815),
>    'Red':     (0.05740000, 1559.4555, 0.011036230),
>    'RedEdge': (0.03930000, 1342.0695, 0.005188136),
>    'NIR1':    (0.09890000, 1069.7302, 0.012243800),
>    'NIR2':    (0.09960000,  861.2866, 0.009042234)}
> The module is flexible to request for any of the bands to be
> converted. Yet, it has the disatvanage that requires the very name(s)
> of the
> corresponding "key(s)" to access the respective calibration factors.
> In short, rename your bands to exactly 'Red', 'Green', 'Blue', 'NIR'.
> Maybe this can be
> changed, but I wouldn't have the time at the moment for it.
> If you have any changes, already, please make a pull request in the
> github repository.
> Nikos
> Nikos
*William Hudspeth, PhD, MPH*
Earth Data Analysis Center
MSC01 1110
1 University of New Mexico
Albuquerque, New Mexico 87131-0001
tel: 505-277-3622, ext. 249
email: bhudspeth at edac.unm.edu
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160916/4eaa1ee8/attachment.html>
