[GRASS-user] r.mask: no MASK created when using many categories
Anna Petrášová kratochanna at gmail.com
Thu Apr 6 18:53:59 PDT 2017
On Thu, Apr 6, 2017 at 5:47 AM, Micha Silver <tsvibar at gmail.com> wrote:
> Interesting...
> I can duplicate the problem (but only up to 100 cats). Above that I get an
> error of "stack smashing":
I tried to fix it in r70847 (or at least allow longer sequences, the
arrays are still statically allocated). But in this case you can also
use "1 thru 106".
Anna
> GRASS 7.2.0 (ITM):~ > r.mask raster=farm_bas maskcats="`seq -s " " 1 100`"
> --o
> All subsequent raster operations will be limited to the MASK area. Removing
> or renaming raster map named 'MASK' will restore raster operations to
> normal.
> [Raster MASK present]
> GRASS 7.2.0 (ITM):~ > r.info -g MASK
> north=530000
> south=510000
> east=185000
> west=170000
> nsres=4
> ewres=4
> rows=5000
> cols=3750
> cells=18750000
> datatype=CELL
> ncats=0
> But with 103 cats...
> GRASS 7.2.0 (ITM):~ > r.mask raster=farm_bas maskcats="`seq -s " " 1 103`"
> --o
> WARNING: MASK already exists and will be overwritten
> *** stack smashing detected ***: r.reclass terminated
> normal.
> ERROR: Raster map <MASK> not found
> On 04/06/2017 12:12 PM, Mira Kattwinkel wrote:
> Dear Anna, dear list
> I used the NC basic sample data set to replicate my case. Unfortunately, I
> get the same problem. Can anybody give me a hint? Thanks a lot!
> Here is what I did and the output:
> r.watershed elevation=elevation at PERMANENT threshold=500 basin=basins_new
> SECTION 1a (of 5): Initiating Memory.
> SECTION 1b (of 5): Determining Offmap Flow.
> SECTION 2: A* Search.
> SECTION 3a: Accumulating Surface Flow with MFD.
> SECTION 3b: Adjusting drainage directions.
> SECTION 4: Watershed determination.
> SECTION 5: Closing Maps.
> ## creating mask with 106 categories  works fine
> r.mask raster=basins_new at PERMANENT maskcats=1 2 3 4 5 6 7 8 9 10 11 12 13 14
> 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
> 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
> 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89
> 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
> normal.
> r.mapcalc expression=r106 = MASK
> r.mask -r
> Raster MASK removed
> ## creating mask with 107 categories seems to work without error but there
> is no MASK output
> 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
> normal.
> r.mapcalc expression=m107 = MASK
> Invalid map <MASK>
> Parse error
> ERROR: parse error
> g.list type=raster
> basins
> basins_new
> elevation
> elevation_shade
> geology
> lakes
> landuse
> r106
> soils
> On 06/04/17 05:06, Anna Petrášová wrote:
> On Wed, Apr 5, 2017 at 8:22 AM, Mira Kattwinkel
> <kattwinkel-mira at uni-landau.de> wrote:
> Dear List,
> I am using r.mask to create a new raster map that only contains certain
> categories given in 'maskcats'. Then, I use r.mapcalc to save the map under
> a new name and (to be on the save side) delete the MASK with r.mask flag
> '-r'. I do this in a loop and it works fine until a case when the number of
> categories to combine is 213 (trail and error lead to 106 as the maximum
> number that works fine). Flag 'verbose' gives the message that a MASK was
> created, but none is there. The problem arises in both cases when I directly
> use Grass or through R using execGrass.
> I tried it on landsat raster from NC sample dataset and it worked.
> Perhaps you could try to replicate it with this sample dataset?
> Anna
> Is there a limit in the number of categories that can be passed to r.mask? I
> did not find any hint about that. Additionally, I wonder why there is no
> error message but in the contrary one that tells me that a MASK was created
> even when it failed.
> In case the details are important (or if anybody has a better idea how to
> achieve what I want): I have a raster map of subcatchemts belonging to
> stream segments created with r.stream.basins. For the endpoints of segments,
> I want to combine these subcatchments to a total catchment raster map
> containing all upstream catchments.
> Thanks a lot,
> Mira
> Dr. Mira Kattwinkel
> Quantitative Landscape Ecology
> Institute for Environmental Sciences
> University of Koblenz-Landau
> Fortstraße 7
> 76829 Landau
> Germany
> Phone: + 49 6341 280-31553
> Office: Building I, Room 2.02
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> cell: +972-523-665918
