[GRASS-user] r.out.gdal to AAIGrid
Jeshua Lacock jeshua at 3DTOPO.com
Thu Aug 3 16:22:45 PDT 2017
> On Aug 3, 2017, at 12:24 PM, Pedro VenĂ¢ncio <pedrongvenancio at gmail.com> wrote:
> I'm using r.out.gdal to export raster data from GRASS to Arc/Info ASCII Grid format, to use in another software (Farsite).
> However, the resulting ASCII files does not have the NODATA_value parameter in the header.
> I've tried gdal_translate and it creates, by default, NODATA_value  -999
> Shouldn't GRASS also create NODATA_valeu in the header file?
Hi Pedro,
Have you tried using the nodata parameter?
r.out.gdal nodata=-999 input=yourFile output=yourFileOutput
Best,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
