[GRASS-user] seeking advice on importing "unprojected" data
Ken Mankoff mankoff at gmail.com
Tue Aug 15 05:38:22 PDT 2017
It seems that my suggested approach might be the right one based on this
thread from 2012:
https://lists.osgeo.org/pipermail/grass-dev/2012-March/058179.html
  -k.
On Tue, Aug 15, 2017 at 1:59 PM, Ken Mankoff <mankoff at gmail.com> wrote:
> Hi GRASS list,
> I'm trying to compare two data sets and need to import them into the same
> location. One is a GeoTIFF in WGS84 lon,lat coordinates. When I create a
> new GRASS location using "-c file.tif" everything appears to work, and
> $ g.region -p
> projection: 99 (unnamed)
> zone:       0
> datum:      wgs84
> ellipsoid:  wgs84
> etc...
> And from gdalinfo:
> Coordinate System is:
> PROJCS["unnamed",
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.257223563,
>                 AUTHORITY["EPSG","7030"]],
>             AUTHORITY["EPSG","6326"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4326"]],
>     PROJECTION["Polar_Stereographic"],
>     PARAMETER["latitude_of_origin",70],
>     PARAMETER["central_meridian",-45],
>     PARAMETER["scale_factor",1],
>     PARAMETER["false_easting",1],
>     PARAMETER["false_northing",1],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]]]
> Origin = (107900.000000000000000,-655550.000000000000000)
> Pixel Size = (30.000000000000000,-30.000000000000000)
> I have a second data set that I would like to co-locate with this one.
> That data comes in a NetCDF file but the projection is a custom
> rotated-pole projection. I have three variables in the NetCDF file: lon,
> lat, and the data.
> What is the best method to convert on data set to the other? My first
> approach might be to convert the NetCDF to lon,lat,data ASCII file, import
> as points with m.proj, then convert to raster. I'm wondering if this is
> what the experts on this list would do. Note that I have one TIF, and
> 50,000 NetCDF time steps, so it may be more efficient to convert the TIF to
> the custom NetCDF projection, but it is not a requirement.
> Thanks for any advice you may have,
>   -k.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170815/cdb9eeda/attachment-0001.html>
