[GRASS-user] g.list ... -1073741701 cntnd
Edmund Swylan Edmund.Swylan at ponymail.com
Thu Aug 17 10:12:06 PDT 2017
I have taken another step back and tried winGRASS 6.4.4 Command Line.
For Spearfish60 7.2.1 responds with 0xc000007b to `g.proj', `g.list type=rast',
`g.list type=vect', and `v.info soils'. It seems to give a reasonable answer to
`r.info soils'.
6.4.4 responds with 0xc000007b to `g.proj' and `v.info soils' and gives
a reasonable answer to `r.info soils'. It also produces both lists.
Don't the differences let reduce significantly the set of suspect .dlls?
Edmund
