[GRASS-user] g.list ... -1073741701
Helmut Kudrnovsky
hellik at web.de
Sun Aug 20 00:54:23 PDT 2017
>C:\>where sqlite3.dll
>'where' is not recognized as an internal or external command,
>operable program or batch file.
sorry, the where command is available in >= WinVista
> the latter I have now introduced into C:\WINDOWS\system32.
it's not recommended (and normally not needed) to change anything by user
directly in the operating systems folder like C:\WINDOWS\system32. too much
risk for mixing and messing up things.
> I have a 95 and several versions of 98.
no newer ones?
>I have also done a 7.2.1 (and Spearfish) installation on another (XP)
>computer - one without any SQLite or QGIS. Same result.
I've co-developed the winGRASS-installers up from the beginning, we tested
it quite a lot on different windows versions and flavors in this long time.
>Yes. And that is why I think I stand a slightly better chance with 6.4.4
>whose PATH seems to be set by three .bats and not by a GRASS...py.
AFAICT there is no fundamental difference in setting %PATH% between the
winGRASS 6.x and winGRASS 7.x line.
>What's scratch? Uninstalling all GRASSes and killing the remaining weeds
>in
yes
>Maybe. But, surely, a network installer has more, not fewer, options than
>a stand-alone one?
the standalone installer is based upon the OSGeo4W-environment; there it's
possible to add step by step new components, e.g.
- first, install only the basic OSGeo4W-environment, which is mostly
GDAL/PROJ4 stuff, which is GRASS based upon
- do some tests, e.g. by ogrinfo yourshapefile.shp, gdalinfo yourgeo.tif,
ogr2ogr newshapefile.shp oldshapefile.shp etc etc
- add winGRASS to the OSGeo4W-environment and do some tests.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-list-1073741701-tp5331416p5331910.html
Sent from the Grass - Users mailing list archive at Nabble.com.
