[GRASS-user] r.watershed
Helmut Kudrnovsky hellik at web.de
Tue Dec 5 14:07:45 PST 2017
Shane Carey wrote
> Hi,
> I am trying to extract river network from a 5m DEM with some success using
> r.watershed. Has anyone tested this algorithm on high resolution LiDAR
> data
> for example - 1meter DTM and what kind of results have they obtained?
in the NC sample dateset there is lidar derived 1m x 1m DEM:
r.info map=elev_lid792_1m at PERMANENT
 | Map:      elev_lid792_1m at PERMANENT       Date: Wed Feb 14 19:45:24 2007
 | Mapset:   PERMANENT                      Login of Creator: helena
 | DataBase: D:\grassdata
 | Title:    Rural area: Lidar-based 1m DEM
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 255
 |   Data Type:    FCELL
 |   Rows:         750
 |   Columns:      700
 |   Total Cells:  525000
 |        Projection: Lambert Conformal Conic
 |            N:     220750    S:     220000   Res:     1
 |            E:     639000    W:     638300   Res:     1
 |   Range of data:    min = 103.7643  max = 131.598
 |   Data Source:
 |    vector file ncfl_lidar_79200WC_pts
 |   Data Description:
 |    generated by v.surf.rst
 |   Comments:
 |    giventension=300.000000, smoothing=1.000000
 |    dnorm=47.606041, dmin=1.000000, zmult=1.000000
 |    segmax=25, npmin=100, rmsdevi=0.222627
 |    zmin_data=103.513000, zmax_data=131.668000
 |    zmin_int=103.764260, zmax_int=131.598045
 |    v.surf.rst -t input="ncfl_lidar_79200WC_pts" layer=0 elev="elev_lid7\
 |    9200_1m" slope="slope_1m" aspect="asp_1m" pcurv="pcurv_1m" tcurv="tc\
 |    urv_1m" tension=300 smooth=1.0 segmax=25 npmin=100 dmin=1 dmax=2.500\
 |    000 zmult=1.0
you can test the module with this DEM to see it's appropriate for your need.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
