[GRASS-user] Creating STRDS from scratch
Laurent C. lrntct at gmail.com
Tue Feb 21 09:38:40 PST 2017
Hello Rich,
In your case, it seems you want to have uniform rainfall. So you can
set the region, and then use mapcalc like so:
r.mapcalc exp='rainfall_2013115=0.1'
And doing the same for each day. A small script could be useful to
automatize the task.
When registering the maps, it's better to set an end_time equal to the
start_time of the next map, to cover the whole period.
Regards,
Laurent
2017-02-21 11:26 GMT-06:00 Rich Shepard <rshepard at appl-ecosys.com>:
> On Tue, 21 Feb 2017, Thomas Adams wrote:
>> ... a critical step is to create a text file that looks like this:
>> PRISM_ppt_4kmM2_1970|1970-01-01 00:00:00|1970-12-31 23:00:00
>> where the first column is the map name of the imported raster map, ...
> Tom,
>   Yes, this works when you have existing map files. What I have is this:
> 2013-11-15      0.10
> 2013-11-16      0.32
> 2013-11-17      0.10
> 2013-12-08      0.23
>   No maps; a list of dates and average precipitation rate in mm/hr.
>   Do I create a set of maps, one per day, from the DEM for the area?
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
