[GRASS-user] GRASS 7.2.1 for centos 7 from copr/neteler repo
Laura Poggio laura.poggio at gmail.com
Fri Jul 21 03:51:25 PDT 2017
Dear all,
I am trying to install GRASS 7.2.1 using the repository neteler-grass72 on
a machine running centos 7 [Linux version 3.10.0-514.26.2.el7.x86_64 (
builder at kbuilder.dev.centos.org) (gcc version 4.8.5 20150623 (Red Hat
4.8.5-11) (GCC) )]
I get the following errors:
Error: Package: grass-libs-7.2.1-6.fc26.x86_64 (neteler-grass72)
           Requires: libproj.so.12()(64bit)
           Requires: libm.so.6(GLIBC_2.23)(64bit)
           Requires: libgdal.so.20()(64bit)
           Requires: libcrypto.so.1.1()(64bit)
           Requires: libpng16.so.16()(64bit)
           Requires: libpng16.so.16(PNG16_0)(64bit)
           Requires: libgeos-3.6.1.so()(64bit)
           Requires: libssl.so.1.1()(64bit)
As far as I can see it requires versions of the libraries that are not
readily available from centos 7 repositories (including epel).
I could compile grass 7.2.1 from source without problems, but I would
prefer to use the repository if at all possible.
What am I missing ? Do I need to compile the dependencies before in order
to have the right versions? Are there any repositories where the rmps could
be found?
Thanks a lot in advance
Laura
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170721/e0066bab/attachment.html>
