[GRASS-user] r.water.outlet map does not display
Rich Shepard rshepard at appl-ecosys.com
Mon Mar 6 14:50:53 PST 2017
   Using r.watershed specifying the input DEM and a name for the drainage map
I can view the drainage map. When I follow this command with r.water.outlet
specifying the drainage map as input, 'watershed' as the output map name,
and the coordinates of the designated outlet, no map is displayable.
   Could this be due to the very flat nature of the terrain?
Rich
