[GRASS-user] r.water.outlet map does not display
Sören Gebbert soerengebbert at googlemail.com
Mon Mar 6 15:47:39 PST 2017
Am 06.03.2017 11:50 PM schrieb "Rich Shepard" <rshepard at appl-ecosys.com>:
  Using r.watershed specifying the input DEM and a name for the drainage map
I can view the drainage map. When I follow this command with r.water.outlet
specifying the drainage map as input, 'watershed' as the output map name,
and the coordinates of the designated outlet, no map is displayable.
  Could this be due to the very flat nature of the terrain?
Yes. The watershed computed via r.water.outlet may be only a single pixel
in size, if your outlet point is not located on a stream. Better use
r.watershed.
Rich
grass-user mailing list
grass-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170307/fb36f8c2/attachment.html>
