[GRASS-user] Setting layer transparency from a script
Nikos Alexandris nik at nikosalexandris.net
Sat Mar 11 01:35:42 PST 2017
Laurent C.:
>Hello,
>I'm using a Python script to generate maps for publication by setting
>GRASS_RENDER_FILE and running the different d.* commands. Is it
>possible to add opacity to some of the layers?
Dear Laurent,
not a direct answer, but you might want to read
<https://lists.osgeo.org/pipermail/grass-user/2016-March/073831.html>
Also, the r.out.png tool has a "-t   Make NULL cells transparent" flag.
Kind regards and thank you for your excellent work I've seen elsewhere.
Nikos
