[GRASS-user] STRDS animation: failed to render
Sören Gebbert soerengebbert at googlemail.com
Wed Mar 22 14:48:18 PDT 2017
unfortunately renaming of raster layers with g.rename is not
recognized by the temporal framework. You have to remove the old strds
and register the renamed maps in a new strds. Using t.rast.list on the
old strds will give you a map list that you can use as template for
registering.
Best regards
Soeren
2017-03-22 22:31 GMT+01:00 Rich Shepard <rshepard at appl-ecosys.com>:
> On Wed, 22 Mar 2017, Anna Petrášová wrote:
>> ... and look if there are any messages in terminal. Can you reproduce that
>> behavior?
> Anna,
>   Yes, and yes. I missed seeing the details when the terminal was obscurred
> by the three GUI windows.
>   It's a name issue: the strds is named blocked_h (as are the individual
> raster maps) but the renderer is looking for open_h instead. For example,
> GRASS_INFO_WARNING(14315,1): Rendering failed:
> GRASS_INFO_WARNING(14315,1): GRASS_INFO_ERROR(14306,1): Raster map
> <open_h_0012 at analyses> not found
>   I used a bash script with sed to rename all raster maps from open_h_* to
> blocked_h_*, then used 't.rename in=open_h out=blocked_h'. The error message
> suggests that somewhere a name was not changed.
>   t.info does not indicate any name differences and t.list shows only
> blocked_h and blocked_wse so why the animator is looking for open_h puzzles
> me.
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
