[GRASS-user] python reserved word as parameter
Ang Sherpa angsherpa232 at gmail.com
Thu Mar 30 20:54:03 PDT 2017
It worked, Thanks.
*Best,*
*Ang Dawa Sherpa*
On Thu, Mar 30, 2017 at 8:26 PM, Micha Silver <tsvibar at gmail.com> wrote:
> Use: "from_"
> On 03/30/2017 05:27 PM, Ang Sherpa wrote:
> Hi users,
> While using "v.distance" in python script. The first parameter is "from"
> which is python reserved keyword and throws error: "There's error in your
> syntax"
> *v.distance* [-*pa*] *from*=*name* [*from_layer*=*string*] [*from_type*=
> *string*[,*string*,...]] *to*=*name* [*to_layer*=*string*] [*to_type*=
> *string*[,*string*,...]] [*output*=*name*] [*dmax*=*float*] [*dmin*=
> *float*] *upload*=*string*[,*string*,...] [*column*=*name*[,*name*,...]] [
> *to_column*=*name*] [*table*=*name*] [*separator*=*character*] [--
> *overwrite*] [--*help*] [--*verbose*] [--*quiet*] [--*ui*]
> Is there a way to resolve this issue?
> *Best,*
> *Ang Dawa Sherpa*
> grass-user mailing listgrass-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170331/729c8398/attachment-0001.html>
