[GRASS-user] cannot write raster w/ max = inf
Markus Neteler neteler at osgeo.org
Fri Nov 10 15:37:27 PST 2017
Hi Ken,
On Sat, Nov 11, 2017 at 12:25 AM, Ken Mankoff <mankoff at gmail.com> wrote:
> Dear GRASS list,
> I have a GeoTIFF that I can read in to a raster.
Can you please post the output of
gdalinfo -mm your_raster_map
> ~r.info~ reports "max = inf".
Sounds like "unusual"...
> If I try to write it out as a raster with ~r.out.gdal~ I get an error (below)
That is likely a error due to above problem.
Markus
> and the file is not saved to disk. I can't figure out how
> to replace "inf" values with ~r.mapcalc~. Can someone suggest how to work with this data?
> Thanks,
>   -k.
> Checking GDAL data type and nodata value...
>  100%
> WARNING: Selected GDAL datatype does not cover data range.
> WARNING: GDAL datatype: Float32, range: -3.4e+38 - 3.4e+38
> WARNING: Raster map <foo> range: 0.393347 - inf
> WARNING: Raster export results in data loss.
> Using GDAL data type <Float32>
> Input raster map contains cells with NULL-value (no-data). The value nan
> will be used to represent no-data values in the input map. You can specify
> a nodata value with the nodata option.
> ERROR: Raster export aborted.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
