[GRASS-user] v.voronoi error: Found 0 points/centroids, but at least 2 are needed
Markus Metz markus.metz.giswork at gmail.com
Sat Nov 25 02:48:48 PST 2017
On Sat, Nov 25, 2017 at 3:07 AM, 洪朝貴 <ckhung at cyut.edu.tw> wrote:
> Dear All,
> I am a linux veteran and a grass newbie comfortable with
> file format conversions and most interested in grass
> v.* commands because of its rich algorithms and
> the possibility of scripting/automation.
> I imported the attached geojson file like this:
>     v.in.ogr input=tkec.geojson output=tkec
> and tried these two commands:
>     v.delaunay input=tkec output=tkecdt
>     v.voronoi input=tkec output=tkecv
> The Delaunay triangulation works perfectly and looks nice
> after I exported it and displayed it in some other program.
> The Voronoi diagram command, however, gives the error message:
>     Found 0 points/centroids in <tkec at work>, but at least 2 are needed
> I tried it in grass 7.0.3 of lubuntu 16.04 and
> grass 7.2.0 of lubuntu 17.04 .
> The error messages are the same.
> Did I miss some steps before calling v.voronoi?
v.voronoi uses the current region (the algorithm requires this), therefore
you need to set an appropriate computational region first, e.g. with
g.region -pa vect=tkec res=1
before using v.voronoi.
> Many thanks in advance for your help!
HTH,
Markus M
> 『我的野蠻工讀生』用高昂的『下賊船的代價』
> 綁架了我的文件! (請分別搜尋)
> Chao-Kuei Hung 洪朝貴
> PGP Key ID: 4096R/5828A7A7
> Fingerprint: 67AF B5AB 5242 3E99 16D7  EAF8 A94D 2C92 5828 A7A7
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171125/282df85b/attachment.html>
