[GRASS-user] r.stream.extract error
Markus Metz markus.metz.giswork at gmail.com
Sun Nov 26 23:31:07 PST 2017
On Mon, Nov 27, 2017 at 3:56 AM, Giuseppe Amatulli <
giuseppe.amatulli at gmail.com> wrote:
> Just finished the test with 100G and the computation finish without
error.
> So my conclusion is:
> even if setting the max value of RAM  in the  r.stream.basins  to
memory=25000 the effective requirements is a bit less the then 100G.
For r.stream.basins you need to use the -m flag, otherwise everything is
done in RAM. A nice enhancement for all affected r.stream.* modules would
be to switch automatically to disk swap mode if the amount of memory needed
for all-in-RAM processing is larger than what is allocated with the
memory=MB option.
> A similar situation happens with r.stream.extract where the requested
used RAM is a bit less then 50G.
This is strange. In my tests, r.stream.extract always uses a bit less than
what is given with the memory option. I could process a raster with
11,612,160,000 cells and memory=25000 and actual peak memory consumption
was about 24000 MB.
Markus M
> Any thoughts?
> Thanks you
> Best
> Giuseppe
> On 26 November 2017 at 20:33, Giuseppe Amatulli <
>> Hi Markus M,
>> I re-tested (size 80490 x 142690 = 11,485,118,100 ) r.stream.extract &
r.stream.basins  setting 25G  RAM  for the 2 commands with a slurm upper
limit of 60G RAM.
>> The r.stream.extract use this RAM
>>        JobID  MaxVMSize
>> 6731334.bat+  47459272K
>> and finish without problem
>> rather r.stream.basins use
>>        JobID  MaxVMSize
>> 6731334.bat+  90241708K
>> and get kill with this error.
>> Reading raster map <stream>...
>> 0..3..6..9..12..15../var/spool/slurmd/job6731334/slurm_script: line 88:
15041 Bus error
/gpfs/home/fas/sbsc/ga254/.grass7/addons/bin/r.stream.basins -l
stream_rast=stream direction=dir basins=lbasin memory=25000 --o --verbose
>> I think something is implemented different in r.stream.basins compare to
r.stream.extract.
>> I will try to ask for more RAM (100G) but I'm afraid that is going to
fail again.
>> Any thoughts?
>> Thanks you
>> Best
>> Giuseppe
>> On 17 November 2017 at 03:33, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>>> On Thu, Nov 16, 2017 at 10:51 PM, Giuseppe Amatulli <
>>> > Hi Markus  M.
>>> > I was testing the r.stream.extract for 2 tiff
>>> > 1) 80040 x 72870 = 5,832,514,800 i got the stream results - no error
>>> Great, that means large maps with more than 2 billion cells are
supported.
>>> > 2) 80490 x 142690 = 11,485,118,100 i got the following error
>>> > A* Search...
>>> > 0..2../var/spool/slurmd/job6514787/slurm_script: line 80: 28925 Bus
error               r.stream.extract elevation=elv accumulation=upa
threshold=0.5 depression=dep direction=dir stream_raster=stream
memory=45000 --o --verbose
>>> From wikipedia:
>>> "a bus error is a fault raised by hardware, notifying an operating
system (OS) that a process is trying to access memory that the CPU cannot
physically address: an invalid address for the address bus, hence the name."
>>> I guess you either need to raise the RAM limit in slurm or slightly
reduce the memory option for r.stream.extract.
>>> Markus M
>>> > Do you think that is something with the slurm ram limitation or is
something with the r.extract.stream?
>>> > If the the stream output have a number of stream segments larger than
2,147,483,647 what is happen?
>>> > Do I get an error or all the value larger than   2,147,483,647 are
just rounded to 2,147,483,647 ?
>>> > Moreover, if use the stream obtain from option 1) and I use the
stream as input for the r.stream.basins
>>> > I got the following error
>>> > reading raster map <stream>...
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45../var/spool/slurmd/job6514788/slurm_script:
line 82: 17687 Bus error
>>> > is this something that need to be fixed in r.stream.basins, or should
i think that is due to other problems
>>> > Thank you
>>> > Giuseppe
>>> > On 10 November 2017 at 11:21, Markus Neteler <neteler at osgeo.org>
wrote:
>>> >> On Wed, Nov 1, 2017 at 10:12 PM, Markus Metz
>>> >> <markus.metz.giswork at gmail.com> wrote:
>>> >> > On Wed, Nov 1, 2017 at 7:15 PM, Giuseppe Amatulli
>>> >> > <giuseppe.amatulli at gmail.com> wrote:
>>> >> >> Thanks Markus!!
>>> >> >> I will test and I will let you know how it works.
>>> >> > Your feedback is very helpful!
>>> >> >> I have few  more questions
>>> >> >> 1) now how much is the upper limit matrix cell number that
>>> >> >> r.stream.extract can handle?
>>> >> > About 1.15e+18 cells.
>>> >> > Another limitation is the number of detected stream segments. This
must not
>>> >> > be larger than 2,147,483,647 streams,
>>> >> (Added as a note to
https://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Some_benchmarks
>>> >> best,
>>> >> markusN
>>> > Giuseppe Amatulli, Ph.D.
>>> > Research scientist at
>>> > Yale School of Forestry & Environmental Studies
>>> > Yale Center for Research Computing
>>> > Center for Science and Social Science Information
>>> > New Haven, 06511
>>> > Teaching: http://spatial-ecology.net
>>> > Work:  https://environment.yale.edu/profile/giuseppe-amatulli/
>> New Haven, 06511
> New Haven, 06511
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171127/f13c2b2d/attachment.html>
