[GRASS-user] Merge lines into common categories based an attribute information
Moritz Lennert mlennert at club.worldonline.be
Mon Sep 18 02:14:47 PDT 2017
On 17/09/17 18:48, Johannes Radinger wrote:
> Thank you Moritz!
> Of course, v.reclass does the job. I just didn't see the column option...
> Regarding the second (additional) part of this question: It seems that
> v.to.db works well to report line lengths on a category-base. However,
> sinuosity seems to be calculated based on features (i.e. feature ids).
> Thus, I only get reasonable results if a cat only consists of one
> feature. For connected lines that consist of more than one feature
> (lines) the sinuosity index is not correct. So, I probably need to loop
> over the cats, extract the lines that belong to one cat and build a
> polyline before calculating sinuosity.
Please file a bug report on this so that someone might at least have a
look at it. ISTR, that this kind of limitation was present for other
indicators in v.to.db and is definitely worth thinking about.
Moritz
