[GRASS-user] Recovering from a build error
Rich Shepard rshepard at appl-ecosys.com
Tue Sep 19 06:06:44 PDT 2017
On Sun, 17 Sep 2017, Rich Shepard wrote:
> Fatal Error: Mismatch between the program and library build versions
> detected.
> The library used 3.0 (wchar_t,compiler with C++ ABI 1009,wx
> containers,compatible with 2.8),
> and wxPython used 3.0 (wchar_t,compiler with C++ ABI 1002,wx
> containers,compatible with 2.8).
> ../../include/Make/Html.make:14: recipe for target 'd.rast.edit.tmp.html'
> failed
> make: *** [d.rast.edit.tmp.html] Error 1
> rm d.rast.edit.tmp.html
>  I've been using wxPython-3.0.2.0 to build grass 7.3.svn for quite a while
> now and ~/.bash_profile tells grass that's what's available:
> export GRASS_WXVERSION=3.0.2.0
> Can grass be adjusted to use 3.0 as well as 2.8?
   Because using wxPython-3.0.2.0 has not before been an issue when building
7.3.svn what might have changed in d.rast.edit.tmp.html to not build with
this wxPython version? I would appreciate having this fixed. If there are
other diagnostics I can run please let me know.
Regards,
Rich
