[GRASS-user] OpenFileGDB input error
Markus Metz markus.metz.giswork at gmail.com
Mon Sep 25 08:35:08 PDT 2017
On Mon, Sep 25, 2017 at 5:31 PM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Mon, 25 Sep 2017, Markus Metz wrote:
>> Can you provide (off-list if necessary) a link to the file? Then others
>> can test as well.
> Markus,
>   The URL to the agency's digital data is
> <http://www.ecy.wa.gov/services/gis/data/data.htm>. Scroll down to
"National
> Hydrography Dataset (NHD) 24k: Major Areas, Streams, & Waterbodies Major
NHD
> water features for cartographic use (3 layers)" and you can download
> NHDmajor.gdb.zip (~36M).
Apparently you confused threads. A link is needed to
2016WSDACropDistribution.gdb.zip.
Markus M
>   When I view the imported map I see only the Major Streams layer to
> display.
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170925/781c398b/attachment.html>
