[GRASS-user] OpenFileGDB input error
Even Rouault even.rouault at spatialys.com
Wed Sep 27 02:15:10 PDT 2017
> > You can force a curve geometry to its linearized version (curves are
> approximated with segments) with:
> > hGeom = OGR_G_ForceTo(hGeom,
> OGR_GT_GetLinear(OGR_G_GetGeometryType(hGeom)))
> Thanks for the hint!
> I'm looking for a way to support non-linear geometries in v.in.ogr. Is
> there any advantage of using OGR_G_ForceTo() instead of
> OGR_G_GetLinearGeometry()?
Ah, I just forgot the existence of OGR_G_GetLinearGeometry(). Might be indeed more
obvious to use. Both use ultimately the same mechanisms for linear approximation.
The main difference being that OGR_G_GetLinearGeometry() returns a new object, whereas
OGR_G_ForceTo() transforms in place.
Evven
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170927/30290c78/attachment.html>
