[GRASS-user] Date import: setting projection units
Rich Shepard rshepard at appl-ecosys.com
Wed Sep 27 16:11:28 PDT 2017
   Trying to import an OpenFileGDB with the following parameters:
Layer name: WQStandards_BeneficialUseDesignations
Geometry: Multi Line String
Feature Count: 764329
Extent: (607675.393548, 81930.638752) - (2554273.406512, 1355726.104279)
Layer SRS WKT:
PROJCS["NAD_1983_HARN_StatePlane_Washington_South_FIPS_4602_Feet",
     GEOGCS["GCS_North_American_1983_HARN",
         DATUM["NAD83_High_Accuracy_Reference_Network",
             SPHEROID["GRS_1980",6378137.0,298.257222101]],
         PRIMEM["Greenwich",0.0],
         UNIT["Degree",0.0174532925199433]],
     PROJECTION["Lambert_Conformal_Conic_2SP"],
     PARAMETER["False_Easting",1640416.666666667],
     PARAMETER["False_Northing",0.0],
     PARAMETER["Central_Meridian",-120.5],
     PARAMETER["Standard_Parallel_1",45.83333333333334],
     PARAMETER["Standard_Parallel_2",47.33333333333334],
     PARAMETER["Latitude_Of_Origin",45.33333333333334],
     UNIT["Foot_US",0.3048006096012192]]
   I created a new location (Washington-LCC):
proj: lcc
lat_1: 45.83
lat_2: 47.33
lat_0: 23
lon_0: -120.5
x_0: 0.1640416
y_0: 0
no_defs: defined
datum: nad83harn
ellps: grs80
towgs84: 0.000,0.000,0.000
but the units are meters, not feet. I don't see where I can specify
projection units when creating the location. Do I edit the
PERMANENT/PROJ_UNITS file?
TIA,
Rich
