[GRASS-user] Finding specific information in the wiki
Robert Andrew Brown brown782 at purdue.edu
Thu Sep 28 10:10:18 PDT 2017
Hi Rich,
I am not sure about using links from outside sources in this user-list, however, below is a link to "stack exchange" on the subject.
By new GUI, if I remember correctly that changed after May 2017? If so, I have not tried that.
If you want to use the rgrass7 you use the initGRASS command in R. This will link R to grass. You will also need to provide the directory path to your GRASS. If you are using a Mac and you do not have administrative privileges you may need to use the "sudo" command.
https://gis.stackexchange.com/questions/206348/how-to-access-the-terminal-in-grass-7-0-4
Best,
-bob
Sent from my iPhone
On Sep 28, 2017, at 12:52 PM, Rich Shepard <rshepard at appl-ecosys.com<mailto:rshepard at appl-ecosys.com>> wrote:
On Thu, 28 Sep 2017, Robert Andrew Brown wrote:
There are packages in R to do this.
Robert,
 Yes, rgrass7 is one such package.
GRASS has a command line "terminal" for this.
 Have used this regularly since before there was the new GUI.
The problem I have found is that you can only use a 32 bit version of R in
the GRASS interface.
 How interesting.
Thanks for the insights,
Rich
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
https://secure-web.cisco.com/1JioY5Ts69jH8T_oF4sCNY796b0hFWNYWCyCPUJnbORz_i95Md91msXxxsq_1-4A87pb2wBoQi4D-9e3G4M2ghmrdF3ESVUkSeEcXgZTZhxYhjrccXBUBng-FIF1WKLe9sU5KTh2I00RS3lVgk6gwoA3le7SMO_RF2iDjNfoNuHmwZb0yktgVdlqkjuZ5Ur2lXZzHNbCycQAqsltLmn5Wpc9uJiiAM6aii3qIkByEIfZ-JH-5iim7dI9fqyhHooAecIw38DYorx7LxpxtjLOhLtNQxDYeGDNFrtKHwLZmZDRl1gbl0WW83-_a8xX5zFLxgvazEewZ2gg4w8k-1b9GRADAf0dwsuwzQ-r-_xW2lPw/https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170928/98db31bd/attachment.html>
