[GRASS-user] g.gui.psmap: set region
Rich Shepard rshepard at appl-ecosys.com
Tue Aug 14 18:36:19 PDT 2018
On Tue, 14 Aug 2018, Anna Petrášová wrote:
> no, you should be able to add maps from any accessible mapset, use
> g.mapsets -s to check your mapsets are accessible.
Anna,
   In the ps.map manual I read setting the region using g.mapsets, but within
the cartographic composer the region setting dropdown choice box did not let
me select a map in a different mapset. Using g.mapsets -s is still on the
command line, not within the GUI as far as I can tell.
Best regards,
Rich
