[GRASS-user] g.gui.psmap: reloading script moves elements
Rich Shepard rshepard at appl-ecosys.com
Tue Aug 21 10:15:51 PDT 2018
   I had to quit the GUI Composer to check elevation units on the base raster
map since I have no access to the command line when g.gui.psmap is active.
When I re-invoked g.gui.psmap and loaded the saved specification file I
discovered that the legend, scale bar, and north arrow were moved from the
saved position and that a frame had been inserted when it was removed from
the saved file.
   Have I done something incorrectly reloading the saved map specifications?
Rich
