[GRASS-user] db.? to change column names
Rich Shepard rshepard at appl-ecosys.com
Fri Aug 31 07:46:58 PDT 2018
On Fri, 31 Aug 2018, Markus Neteler wrote:
> Maybe this helps: it allows to rename a column in the attribute table
> connected to a given vector map:
> https://grass.osgeo.org/grass74/manuals/v.db.renamecolumn.html
Markus,
   Yes, it would help.
   Because I wanted to modify the database I looked at the db.* modules and
didn't think to look for any v.db.* modules. I know about v.to.db, but did
not consider that a strictly database manipulation would be a vector
command.
   Would it be helpful (and practical) to put (in this case) a "See also:
vector commands" section at the bottom of each module category page that
would point to applicable alternatives? Perhaps even suggesint looking for
extension modules.
Best regards,
Rich
